163
How can I determine if a process is running or not and then have a bash script execute some stuff based on that condition?
For example:
  • if process abc is running, do this
  • if it is not running, do that.
the
  • 845
Nirmik
  • 7,938
12 Answers12
244
A bash script to do something like that would look something like this:
#!/bin/bash
# Check if gedit is running
# -x flag only match processes whose name (or command line if -f is
# specified) exactly match the pattern.
if pgrep -x "gedit" > /dev/null
then
    echo "Running"
else
    echo "Stopped"
fi
This script is just checking to see if the program "gedit" is running.
Or you can only check if the program is not running like this:
if ! pgrep -x "gedit" > /dev/null
then
    echo "Stopped"
fi
John Vrbanac
  • 4,727
43
Any solution that uses something like ps aux | grep abc or pgrep abc are flawed.
Why?
Because you are not checking if a specific process is running, you are checking if there are any processes running that happens to match abc. Any user can easily create and run an executable named abc (or that contains abc somewhere in its name or arguments), causing a false positive for your test. There are various options you can apply to ps, grep and pgrep to narrow the search, but you still won't get a reliable test.
So how do I reliably test for a certain running process?
That depends on what you need the test for.
I want to ensure that service abc is running, and if not, start it
This is what systemd is for. It can start the service automatically and keep track of it, and it can react when it dies.
See How can I check to see if my game server is still running... for other solutions.
abc is my script. I need to make sure only one instance of my script is running.
In this case, use a lockfile or a lockdir. E.g.
#!/usr/bin/env bash
if ! mkdir /tmp/abc.lock; then
    printf "Failed to acquire lock.\n" >&2
    exit 1
fi
trap 'rm -rf /tmp/abc.lock' EXIT  # remove the lockdir on exit
# rest of script ...
See Bash FAQ 45 for other ways of locking.
geirha
  • 47,279
21
This is what I use:
#!/bin/bash
#check if abc is running
if pgrep abc >/dev/null 2>&1
  then
     # abc is running
  else
     # abc is not running
fi
In plain English: if 'pgrep' returns 0, the process is running, otherwise it is not.
Related reading:
Bash Scripting :: String Comparisons
Ubuntu Manuals pgrep
Zuul
  • 2,044
I usually have a pidof -x $(basename $0) on my scripts to check if it's already running.
Riffing on @rommel-cid's idea, you can use pidof with the || (||) to run a command if the process does not exist and && to run something if the process does exist, thus creating a quick if/then/else conditional. For example here's one with a running process (my chrome browser, whose process name is "chrome") and one testing for a process that does not exist. I suppressed the standard output using 1>/dev/null so that it doesn't print:
$ (pidof chrome 1>/dev/null && echo "its running? ok, so am i then" ) || echo "it's not running? ok i'll run instea\
d"
$ (pidof nosuchprocess 1>/dev/null && echo "its running? ok, so am i then" ) || echo "it's not running? ok i'll run\
 instead"
it's not running? ok i'll run instead
yuvilio
  • 3,419
By pid:
test -d /proc/[pid]
By name:
pgrep -u [user] -x [name] >/dev/null
"-x" means "exact match".
## bash
## function to check if a process is alive and running:
_isRunning() {
    ps -o comm= -C "$1" 2>/dev/null | grep -x "$1" >/dev/null 2>&1
## example 1: checking if "gedit" is running
if _isRunning gedit; then
    echo "gedit is running"
else
    echo "gedit is not running"
fi
## example 2: start lxpanel if it is not there
if ! _isRunning lxpanel; then
    lxpanel &
fi
## or
_isRunning lxpanel || (lxpanel &)
Note: pgrep -x lxpanel or pidof lxpanel still reports that lxpanel is running even when it is defunct (zombie); so to get alive-and-running process, we need to use ps and grep
Bach Lien
  • 139
None of the "simple" solutions worked for me because the binary I need to check is not installed system-wide, so I have to check with path, which in turn requires using ps -ef | grep approach:
app="$_sdir/Logic 1.2.18 (64-bit)/Logic"
app_pid=`ps -ef | grep "$app" | awk '{print $2}'`
if `ps -p $app_pid > /dev/null`; then
    echo "An instance of logic analyzer is appear to be running."
    echo "Not starting another instance."
    exit 5
else
    nohup "$app" &> /dev/null &
fi
ceremcem
  • 189
First thing that came to my mind for your problem:
ps aux | grep -i abc will show the details of the process if its running. You may match the number of lines or time for which its running and compare with zero or any other manipulation. When you run the above command it will show you atleast one line of output i.e. detail about the process created by thi grep command.. So take care of that.
That should do as a simple hack. Put it in the bash script and see if its helpful.
drake01
  • 3,515
Using start-stop-daemon:
/sbin/start-stop-daemon --background --make-pidfile --pidfile /tmp/foo.pid -S --startas /usr/bin/program -- arg1 arg2
It works as normal user.
-1
I found that the accepted answer posted by @John Vrbanac did not work for me, and that the answer posted by @geirha doesn't answer the original question.
John Vrbanac's solution didn't work to check if a PHP process was running or not for me, I'm running CentOS 7.
@geirha's answer only makes sure an instance isn't already running before starting another. This was not the original question, the original question was to check if a process is running or not.
Here's what worked for me:
Say my process had the string "Jane" in it's process name. This will find if it's running or not. This works for BASH and PHP scripts.
ps -aux | grep "[J]ane" > /dev/null 2>&1
if [[ "$?" == "0" ]]; then
    echo "It's running"
else
    echo "It's not running"
fi
-1
#!/bin/bash
while [ true ]; do     # Endless loop.
  pid=`pgrep -x ${1}`  # Get a pid.
  if [ -z $pid ]; then # If there is none,
    ${1} &             # Start Param to background.
  else
    sleep 60           # Else wait.
  fi
done
