Possible Duplicate:
How do I get GIMP 2.8?
I tried using sudo add-apt-repository ppa:otto-kesselgulasch/gimp and got this message:
[sudo] password for neil:
You are about to add the following PPA to your system:
 CAUTION!
This PPA could break your installed OS if you use Ubuntu series < Precise. There are dependency issues for Oneiric Ocelot (11.10). Only use it if you know what you do!
There are known issues in Precise Pangolin (12.04).
Regards
 More info: https://launchpad.net/~otto-kesselgulasch/+archive/gimp
Press [ENTER] to continue or ctrl-c to cancel adding it
neilH
  • 63
Yes the problem with oneric not precise.
Just press Enter.
Then run sudo apt-get update
After that run sudo apt-get install gimp
Known issues are ok. Every application has bugs. Isn't it.
Web-E
  • 21,716
