My synaptic package manager in ubuntu is giving error:
Unable to get exclusive lock
This usually means that another package management application(like apt-get or
aptitude) is already running. Please close that application first.
I had the same problem. This post helped however, the pa aux command and the Kill command were ineffective. sudo rm /var/lib/dpkg/lock seemed to work, and I followed it up by another Linux post.
You need sudo rights, so the full command is:
sudo dpkg --configure -aTry using Konsole terminal program instead. Make sure that all package managers are closed! Issue the commands:
sudo apt-get update sudo apt-get upgrade
The sudo apt-get update command worked.
The sudo apt-get upgrade one did not as it stated could not get dns proxy.
Also the following came up:
some files failed to upload using old files.
At least the update was able to fetch 39 of them. The other is irrelevant as this is the latest Ubuntu 12.04 64-bit.
As mentioned in the other answer, you have to make sure that no other package management software is running.
Open a terminal and type the following command
ps aux | grep program-name
where program-name can be apt, software etc. (just to find out if apt-get or Software Center are running). If you get entries for them, note down their process id. Let it be xxxx. Then give the following command.
kill xxxx
Now try opening synaptic.
If the problem still persists, give the following command in the terminal,
Now synaptic should hopefully open.
This error means that anoher Package Management Software is already running and using the files which for example contain the sources for the software. I would look for working processes like apt-get or aptitude with the system-monitor and exit them. Than restart synaptic and it should work.
