I had a wired network connection that worked fine in Ubuntu 11.10.
I upgraded to 12.04 and immediately after the upgrade was completed, the OS reported my cable unplugged.
It was not unplugged and was not defective.
I have a D-link DFE-530TXS 10/100 ethernet NIC and I see what seems to be the generic 10050 driver loaded.
Is there any way to just flush anything and everything to do with the network configuration and have Ubuntu reset/find everything again?
If not, is there any way, I can get it to realize that my network cable is not unplugged? (considering it worked mere minutes before).
Braiam
  • 69,112
Daniel
Sounds crazy, but:
  1. How are the LEDs on the physical connection? Nearly all have leds, and if no LEDs are present typically the cord/instantiating end are at fault.
  2. If LEDs are present- are they "solid" or blinking?
  3. If Solid? Probably a driver or hardware issue. Replace the hardware and troubleshoot. (frys electronics has a 15-day return policy. Just saying.)
  4. If Blinking? Must be driver/configuration related. Post a relevantly censored printout of the command:
    ifconfig -a
Anwar
  • 77,855
I had this problem on the latest 12.04 upgrade (I was already on 12.04, but an innocent-looking system update killed it).
Do you have settings for your interface in /etc/network/interfaces ? I have. This link may help: http://wiki.debian.org/NetworkManager#Wired_Networks_are_Unmanaged
In the end I un-installed Network Manager and it allows the standard /etc/network/interfaces stuff to work properly.
Anwar
  • 77,855
Dan
