I do not like one key shortcuts. Whenever I press this while writing, one key triggers unneeded software. Thus, I have some problems :
  • How can I close Alt shortcuts? ( pressing Alt triggers to type your command )
  • How can I close SuperKey shortcuts ?
  • How can I close Ctrl shortcuts ?
atenz
  • 12,858
Download and Install compizconfig-settings-manager Install compizconfig-settings-manager.
Warning: Compiz config settings manager is an advanced tool and improper use may break your unity interface. It is always a good idea to write down all the changes you make, so that in case something evil happens, it is easy to revert.
Launch the program and in the Desktop section you will find "Ubuntu Unity Plugin". From here you can edit the unity shortcuts under the Behavior/Switcher tabs.
upapilot
  • 2,996
