I am using Toshiba L510 AND Ubuntu 12.04. I Cannot control brightness of my system using function keys. What could be the cause?
Braiam
  • 69,112
ANURAJ
5 Answers5
Open a terminal using Ctrl+Alt+t and type sudo apt-get install xbacklight. That will install xbacklight Install xbacklight if it isn't already there (I can't remember whether it's a default package!).
Then type xbacklight -set x replacing the x with a number between 1 and 99 to set the percentage brightness for your screen backlight. You can actually set to 0 (and I do because I hate bright screens) but I understand that can cause problems on some displays so I don't recommend trying it.
I just wanted to add, you can then set a keyboard shortcut to something like xbacklight -inc 10 to increase the brightness by 10%.
Unfortunately, you can't use Fn + Another Key since like he said, Fn is reserved for the BIOS. It's weird because my Fn + F7 works in turning off/on the screen, and Fn + F2 works in turning off (but not on) my wifi, but F5 and F6 do not adjust brightness... Hope someone can find a real fix soon.
Oyibo
  • 1,917
javon27
  • 111
Try adding acpi_backlight=vendor as a boot option. To do that, open a terminal window, and run
gksu gedit /etc/default/grub
Locate this line: GRUB_CMDLINE_LINUX="".
Edit it to look like this: GRUB_CMDLINE_LINUX="acpi_backlight=vendor"
Save the file, then, in a terminal, run sudo update-grub.
Reboot, and check if the brightness keys work.
That worked for me!
Related link : Brightness function keys not working
I had the same problem on my Toshiba
I installed fnfxd package search synaptics Package Manger for it or
sudo apt-get install fnfxd
It solved my problem
Braiam
  • 69,112
This has fixed it both on a Toshiba L510 and a P850.
1) Edit /etc/default/grub and change this variable:
GRUB_CMDLINE_LINUX="pcie_aspm=force acpi_osi=Linux acpi_backlight=legacy"
2) Edit /etc/modprobe.d/blacklist.conf and add this line at the end of the file:
blacklist toshiba_acpi
3) Update the grub config file:
sudo update-grub
4.) Reboot.
