quickly tutorial
Result: An empty Yelp window with the XML file opened in gedit.
yelp /usr/share/quickly/templates/ubuntu-application/help/tutorial.xml --> Exactly the same problem.
Worked fine a few days ago.
Manually changing the file association of XML files to Yelp (which I actually don't want to do, because all other XML files should open in gedit), and then running the command again gets my system into an infinite loop.
