How to set up RAID 1 (software, hardware or fake) on Ubuntu 12.04 desktop?
RAID 1 is mirroring; where data is duplicated on two different drives using either a hardware RAID controller or software (via the operating system). If either drive fails, the other continues to function as a single drive until the failed drive is replaced.
First thing that needs to be done is to install mdadm. To do so
Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
apt-get install mdadm
Or use USC
Once that is done,
mdadm
--create creates a new RAID device
and follow the instructions
If you want to install on a boot volume with RAID, you can't use the desktop install CD. You need to use the "alternate install" CD:
http://www.ubuntu.com/download/desktop/alternative-downloads
Inside that installer you'll have the options to create a RAID (MD) device and/or use LVM.
https://help.ubuntu.com/community/Installation#Installing_on_external_or_RAID_hard_disks
- 216
