I tried today to install a dvb-card on my Ubuntu 12.04 (Linux blauhai-linux 3.2.0-25-generic #40-Ubuntu SMP Wed May 23 20:30:51 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
). The installation failed with an error. After that, i tried to install python (it was already installed but i got this error):
linux:~$ sudo apt-get install git
Reading package lists... Done
Building dependency tree
git is already the newest version.
You might want to run 'apt-get -f install' to correct these:
python-glade2:i386 : Depends: python:i386 (< 2.5) but it is not going to be installed
Depends: python-support:i386 (>= 0.3.4) but it is not installable
Depends: python:i386 (>= 2.4) but it is not going to be installed
Depends: libglade2-0:i386 (>= 1:2.5.1) but it is not going to be installed
Depends: python-gtk2:i386 (= 2.8.6-8) but it is not going to be installed
python-numeric:i386 : Depends: python:i386 (< 2.5) but it is not going to be installed
Depends: python:i386 (>= 2.3) but it is not going to be installed
Depends: python-central:i386 (>= 0.5.7) but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
well, i can read and tried the proposed command, but then i get this:
linux:~$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libopenal1:i386 libsdl-ttf2.0-0:i386 libkrb5-3:i386 libgconf-2-4:i386 libsm-dev libatk1.0-0:i386 libk5crypto3:i386 libstdc++5:i386 libqt4-declarative:i386
libxcomposite1:i386 libice-dev libgail18:i386 libldap-2.4-2:i386 libao-common libv4l-0:i386 liblcms1:i386 libqt4-qt3support:i386 libroken18-heimdal:i386
libunistring0:i386 libcupsimage2:i386 libgphoto2-port0:i386 libidn11:i386 libnss3:i386 libcaca0:i386 gtk2-engines:i386 libgudev-1.0-0:i386
libjpeg-turbo8:i386 libpthread-stubs0 libcairo-gobject2:i386 libavc1394-0:i386 libjpeg8:i386 libotr2 libaio1:i386 libsane:i386 odbcinst1debian2
odbcinst1debian2:i386 libqt4-test:i386 libqt4-script:i386 libqt4-designer:i386 libsdl-mixer1.2:i386 libqt4-network:i386 libqt4-dbus:i386 libcap2:i386
libproxy1:i386 ibus-gtk:i386 libdbus-glib-1-2:i386 libtdb1:i386 libasn1-8-heimdal:i386 libspeex1:i386 libxslt1.1:i386 libgomp1:i386 libcapi20-3:i386
libibus-1.0-0:i386 libcairo2:i386 libgnutls26:i386 libopenal-data odbcinst libgssapi3-heimdal:i386 libcanberra0:i386 libtasn1-3:i386 libfreetype6:i386
x11proto-kb-dev gtk2-engines-murrine:i386 libwavpack1:i386 libqt4-opengl:i386 libsoup-gnome2.4-1:i386 libv4lconvert0:i386 gstreamer0.10-plugins-good:i386
libc6-i386 lib32gcc1 libqt4-xmlpatterns:i386 librsvg2-common:i386 libdatrie1:i386 xtrans-dev libavahi-common-data:i386 libiec61883-0:i386 lib32asound2
libgdk-pixbuf2.0-0:i386 libsdl-image1.2:i386 libp11-kit0:i386 x11proto-input-dev libwind0-heimdal:i386 libpixman-1-0:i386 libsdl1.2debian:i386 libxaw7:i386
libgdbm3:i386 libcups2:i386 libcurl3:i386 libqtcore4:i386 libxinerama1:i386 libesd0:i386 libmikmod2:i386 libkrb5support0:i386 libxft2:i386 libxt-dev
libcroco3:i386 libpulse-mainloop-glib0:i386 libice6:i386 libaa1:i386 libieee1284-3:i386 libgcrypt11:i386 libthai0:i386 libao4:i386 libkeyutils1:i386
libxmu6:i386 libcanberra-gtk0:i386 libvorbisfile3:i386 libqt4-sql:i386 esound-common libxpm4:i386 libqt4-svg:i386 libusb-0.1-4:i386 libgail-common:i386
libxrender1:i386 libhcrypto4-heimdal:i386 libraw1394-11:i386 libnspr4:i386 libshout3:i386 libdv4:i386 libhx509-5-heimdal:i386 libxau-dev libqt4-xml:i386
gstreamer0.10-x:i386 libgettextpo0:i386 libxss1:i386 libgd2-xpm:i386 libheimbase1-heimdal:i386 libtiff4:i386 libsdl-net1.2:i386 libjasper1:i386
libgnome-keyring0:i386 libxtst6:i386 gtk2-engines-pixbuf:i386 libqtgui4:i386 libtag1c2a:i386 librsvg2-2:i386 libavahi-client3:i386 libssl0.9.8:i386
libmpg123-0:i386 libmad0:i386 libsasl2-2:i386 xorg-sgml-doctools libgsoap1 gtk2-engines-oxygen:i386 libfontconfig1:i386 xaw3dg:i386 libpango1.0-0:i386
libsm6:i386 libx11-dev libheimntlm0-heimdal:i386 libpulsedsp:i386 lib32stdc++6 libx11-doc libqt4-sql-mysql:i386 libxcb-render0:i386 libodbc1:i386
libexif12:i386 libqt4-scripttools:i386 librtmp0:i386 libgssapi-krb5-2:i386 libxi6:i386 libqtwebkit4:i386 libxcb1-dev libxp6:i386 libaudio2:i386
libxcursor1:i386 libxcb-shm0:i386 libxt6:i386 libxv1:i386 libsasl2-modules:i386 libavahi-common3:i386 libxrandr2:i386 x11proto-core-dev libsqlite3-0:i386
libmng1:i386 libgtk2.0-0:i386 libxdmcp-dev libpthread-stubs0-dev libltdl7:i386 libkrb5-26-heimdal:i386 libssl1.0.0:i386 glib-networking:i386
libgpg-error0:i386 libsoup2.4-1:i386 libgphoto2-2:i386 libtag1-vanilla:i386 libaudiofile1:i386 libglade2-0:i386
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
default-jre default-jre-headless icedtea-6-jre-cacao icedtea-6-jre-jamvm icedtea-netx icedtea-netx-common libglade2-0:i386 libpython3.2 openjdk-6-jre
openjdk-6-jre-headless openjdk-6-jre-lib python3 python3-minimal python3-uno python3.2 python3.2-minimal
Suggested packages:
icedtea-plugin sun-java6-fonts fonts-ipafont-gothic fonts-ipafont-mincho ttf-telugu-fonts ttf-oriya-fonts ttf-kannada-fonts ttf-bengali-fonts python3-doc
python3-tk python3.2-doc binfmt-support
The following packages will be REMOVED:
activity-log-manager-control-center aisleriot alacarte apparmor apport apport-gtk apt-xapian-index aptdaemon apturl apturl-common bluez bluez-alsa
bluez-alsa:i386 bluez-gstreamer checkbox checkbox-qt command-not-found compiz compiz-gnome compiz-plugins-main-default compizconfig-backend-gconf deja-dup
duplicity eog evolution-data-server firefox firefox-globalmenu firefox-gnome-support foomatic-db-compressed-ppds gconf-editor gconf2 gdb gedit
gir1.2-mutter-3.0 gir1.2-peas-1.0 gir1.2-rb-3.0 gir1.2-totem-1.0 gir1.2-ubuntuoneui-3.0 gksu gnome-applets gnome-applets-data gnome-bluetooth gnome-contacts
gnome-control-center gnome-media gnome-menus gnome-orca gnome-panel gnome-panel-data gnome-session-fallback gnome-shell gnome-sudoku gnome-terminal
gnome-terminal-data gnome-themes-standard gnome-tweak-tool gnome-user-share gstreamer0.10-gconf gwibber gwibber-service gwibber-service-facebook
gwibber-service-identica gwibber-service-twitter hplip hplip-data ia32-libs ia32-libs-multiarch:i386 ibus ibus-pinyin ibus-table indicator-datetime
indicator-power jockey-common jockey-gtk landscape-client-ui-install language-selector-common language-selector-gnome launchpad-integration
libcanberra-gtk-module libcanberra-gtk-module:i386 libcanberra-gtk3-module libcompizconfig0 libfolks-eds25 libgksu2-0 libgnome-media-profiles-3.0-0
libgnome2-0 libgnome2-common libgnomevfs2-0 libgnomevfs2-common libgweather-3-0 libgweather-common libgwibber-gtk2 libgwibber2 libmetacity-private0
libmutter0 libpeas-1.0-0 libpurple-bin libpython2.7 libreoffice-gnome librhythmbox-core5 libsyncdaemon-1.0-1 libtotem0 libubuntuoneui-3.0-1 light-themes
lsb-release metacity metacity-common mutter-common nautilus-dropbox nautilus-share network-manager-gnome nvidia-common nvidia-settings
nvidia-settings-updates onboard oneconf openjdk-7-jdk openjdk-7-jre openprinting-ppds pidgin pidgin-libnotify pidgin-otr printer-driver-foo2zjs
printer-driver-ptouch printer-driver-pxljr printer-driver-sag-gdi printer-driver-splix python python-appindicator python-apport python-apt python-apt-common
python-aptdaemon python-aptdaemon.gtk3widgets python-aptdaemon.pkcompat python-brlapi python-cairo python-central python-chardet python-configglue
python-crypto python-cups python-cupshelpers python-dateutil python-dbus python-debian python-debtagshw python-defer python-dirspec python-egenix-mxdatetime
python-egenix-mxtools python-gconf python-gdbm python-gi python-gi-cairo python-glade2:i386 python-gmenu python-gnomekeyring python-gnupginterface
python-gobject python-gobject-2 python-gpgme python-gst0.10 python-gtk2 python-httplib2 python-ibus python-imaging python-keyring python-launchpadlib
python-lazr.restfulclient python-lazr.uri python-libproxy python-libxml2 python-louis python-mako python-markupsafe python-minimal python-notify
python-numeric:i386 python-oauth python-openssl python-packagekit python-pam python-pexpect python-piston-mini-client python-pkg-resources
python-problem-report python-protobuf python-pyatspi2 python-pycurl python-pyinotify python-renderpm python-reportlab python-reportlab-accel python-serial
python-simplejson python-smbc python-software-properties python-speechd python-twisted-bin python-twisted-core python-twisted-names python-twisted-web
python-ubuntu-sso-client python-ubuntuone-client python-ubuntuone-control-panel python-ubuntuone-storageprotocol python-uno python-virtkey python-wadllib
python-xapian python-xdg python-xkit python-zeitgeist python-zope.interface python2.7 python2.7-minimal rhythmbox rhythmbox-mozilla
rhythmbox-plugin-cdrecorder rhythmbox-plugin-magnatune rhythmbox-plugin-zeitgeist rhythmbox-plugins rhythmbox-ubuntuone screen-resolution-extra
sessioninstaller skype software-center software-center-aptdaemon-plugins software-properties-common software-properties-gtk system-config-printer-common
system-config-printer-gnome system-config-printer-udev texlive-extra-utils totem totem-mozilla totem-plugins ubuntu-artwork ubuntu-desktop ubuntu-minimal
ubuntu-sso-client ubuntu-sso-client-gtk ubuntu-standard ubuntu-system-service ubuntuone-client ubuntuone-client-gnome ubuntuone-control-panel
ubuntuone-couch ubuntuone-installer ufw unattended-upgrades unity unity-2d unity-common unity-lens-applications unity-lens-video unity-scope-musicstores
unity-scope-video-remote update-manager update-manager-core update-notifier update-notifier-common usb-creator-common usb-creator-gtk virtualbox
virtualbox-dkms virtualbox-qt xdiagnose xul-ext-ubufox zeitgeist zeitgeist-core zeitgeist-datahub
The following NEW packages will be installed:
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
python-minimal python2.7-minimal (due to python-minimal)
0 upgraded, 16 newly installed, 273 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 39.1 MB of archives.
After this operation, 324 MB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
Thats not good, is it?! Should i run this command or should i run another command to fix this problem? Would be great if somebody can help me. :) Thanks in advance.
best regards
