I have a T901 Fujitsu with a touch screen and I want to disable the hand input, but leave the input from the pen so I can easily write on my screen without my hand interfering. Does anyone know of a simple(ish) way of doing this?
Hope you're still interested in the answer: yes, there is a very easy way to do this. The trick is xsetwacom, the programme that takes care of most touch screen related stuff.
If you enter xsetwacom --list devices in a terminal, a list should show up with the different touch screen devices on your computer. For me it shows:
tomas@EliteBook:~$ xsetwacom --list devices
Serial Wacom Tablet stylus id: 16 type: STYLUS
Serial Wacom Tablet eraser id: 18 type: ERASER
Serial Wacom Tablet touch id: 19 type: TOUCH
All you should need to do is turn the Touch parameter off for one of these devices (it worked for me whether I did it for the stylus or the touch). In my case I enter:
xsetwacom --set 19 touch off
You might want to replace the number with whatever shows up on your computer, or better yet, the name of the device in "quotes", as the number might change when other devices have been connected to your computer . If you turn that into a script, you could even bind it to a shortkey through e.g. CCSM.
Hope the information is still useful for you, please let me know if it is and explain why not if it isn't.
- 1,099
