I originally had Windows XP on my computer. Then I decided to download Ubuntu 12.04. I didn't use any CDs or USBs or anything. I did not know that in doing so I wouldn't have access to any of my files. If I switch back to XP will my files still be there? If so, how do I switch back?
Sounds like that you are using Wubi since you said that you didn't use any USB drives and CD's.
To access your C Drive in Wubi, click the Folder icon on the launcher, then click File System on the sidebar. Go to /host and you will see your C drive on Windows XP.
To uninstall Ubuntu, go to the Control Panel and uninstall "Ubuntu".
Your files will still be there as usual. But not those files that you created in Ubuntu.
- 6,940
If you mean you used wubi, then yes, your files should still be there. If you used a live cd/dvd/usb, It's possible you could have deleted XP. Does it show XP at the boot menu? If so, navigating to it and pressing enter should boot your old OS. If XP doesn't appear in the boot menu, then most likely you're out of luck.
- 419
I guess you mean you use wubi installation method. i.e Install Ubuntu inside Windows as a seperate application. In this case, Windows should not be deleted. You can easily access Windows at boot menu. Boot menu is a menu which provide you to choose from existing OS to boot.
If you are referring to boot into the XP, yes, you will find your files there. But if you are referring to Installing XP again by removing Ubuntu installation, which probably be installed inside the Windows. You will not get your file, if you install XP again in the same partition.
You can uninstall Ubuntu (if you used wubi method) just as like as you uninstall any other program in XP. Going to control-center --> Add/Remove Program
- 77,855
