How i can optimize the power consumption of the open source radeon driver? I don't want to use official amd driver cause of an error with sleep mode.
AMD E-450 cpu\gpu.
Open a terminal, and copy the following
echo dynpm|sudo tee /sys/class/drm/card0/device/power_method
If you do not like it, you can return back by using
echo profile|sudo tee /sys/class/drm/card0/device/power_method
If you want to set at boot, type
sudo gedit /etc/rc.local
and add before "exit 0"
echo dynpm > /sys/class/drm/card0/device/power_method
This may reduce the performance
