I use Ubuntu Mate 24.04.02
Often I start the terminal with the command :
ffmpeg -i
And via drag and drop of the video-file in to the terminal I get the information what I want to have.
I did use the terminal settings : command during start, but it executes the command and close the terminal after all. Obviously the terminal will be started and an internal additional "Enter" performs the command.
My Question : Is it possible to start a terminal with a "string" in the command line, so I can complete the command via drag + drop ?
Gloster
  • 33
You can do this by using xdotool and adding it to your .bashrc file.
  1. Install the xdotool in your system:
    sudo apt update
    sudo apt install xdotool
  2. Edit the .bashrc file of your current user:
    nano ~/.bashrc
  3. Insert the following xdotool command at the end of the file:
    xdotool type "ffmpeg -i"
  4. Save and exit the file using the shortcuts Ctrl+S and Ctrl+X. Now, when you open a new terminal, the command will already be present in the terminal.
Ajay
  • 2,241
