Thank you! To complete the record, the "permissions" option seems to have been the ticket. I just hope they're sticky ;-) On to the next problem.
I have a new (to me) system that has a 500GB SSD and a 4TB HD. I have windows and Ubuntu 24.04.2 installed on the SSD (SDA), and want to put user files on the HD (SDB). In order to share the HD I left it NTFS. Now I want it to be /home, so all user files go to it. I've been playing around for quite a wile, and can't get it mounted R/W. Finally leaving aside all the Q&A that applies to several different releases, I went to the man file for NTFS-3g,
I ran "powercfg/h off" in win, as mentioned in the man page. My most recent shot at /etc/fstab is below. If I don't have this entry in fstab I can access the drive just fine from Nautilus, create and edit files, etc. I think I'm just missing some magic incantation in fstab. TIA.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda5 during curtin installation
/dev/disk/by-uuid/111840ce-9375-4ff0-963f-f26613b189b2 / ext4 defaults 0 1
# /boot/efi was on /dev/sda1 during curtin installation
/dev/disk/by-uuid/0666-209E /boot/efi vfat defaults 0 1
/swap.img none swap sw 0 0
/dev/disk/by-uuid/8002836D0283674E /home ntfs-3g umask=0000 0 2```
