when i press a command which is not installed the system suggests only snap packages, not deb. I use ubuntu 25.04
Command 'node' not found, did you mean:
command 'nodo' from snap nodo (master)
command 'code' from snap code (258e40fe)
See 'snap info <snapname>' for additional versions.
node can be installed with sudo apt install nodejs
but the system doesn't show it
