Video Bus
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x0 product 0x6 version 0x0
Input device name: "Video Bus"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 227 (KEY_SWITCHVIDEOMODE)
Event code 241 (KEY_VIDEO_NEXT)
Event code 242 (KEY_VIDEO_PREV)
Event code 243 (KEY_BRIGHTNESS_CYCLE)
Event code 244 (KEY_BRIGHTNESS_ZERO)
Event code 245 (KEY_DISPLAY_OFF)
MSI WMI hotkeys
Input device ID: bus 0x19 vendor 0x0 product 0x0 version 0x0
Input device name: "MSI WMI hotkeys"
Supported events:
Event code 113 (KEY_MUTE)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 148 (KEY_PROG1)
Event code 149 (KEY_PROG2)
Event code 240 (KEY_UNKNOWN)
Using kubuntu 24.04.2lts, using whatever base drivers this comes with (i have not made any changes other than switch to wayland), i am specifically running this on an MSI Modern 15 B7M-229au
i am doing this on an msi laptop which i assume is why the MSI WMI hotkeys thing is here in the first place
it is also showing acpi things when using acpi_listen. I know it is Video Bus doing the random brightness changes because using evtest i can see it randomly doing the brightness up key. whereas MSI WMI hotkeys does not do the random events
i tried disabling one with a udev rule but it didnt seem to be doing anything. i tried blacklisting the "video" driver - still didnt work.
I am using wayland if this helps any.
I am really stumped and any help would be greatly appreciated
