I've followed the ubuntu help docs for setting up NFSv4 on a server running Ubuntu 10.4LTS and now I'm trying to get Autofs (on ubuntu 10.10) to mount the exports, following these instructions. So far it doesn't work.
Where the docs say server -fstype=nfs4 server:/ I'm supposed to replace 'server' with my server's hostname right? If yes, should that be server-foo or server-foo.local?
# Sample /etc/auto.master file
#  --- comments snipped --8<--
+auto.master            # pre-existing
/nfs   /etc/auto.nfs    # added by me
# manually created /etc/auto.nfs
ubuntu-server.local   -fstype=nfs4   ubuntu-server.local:/
ls /nfs/ubuntu-server /nfs/ubuntu-server.local shows nothing. What's the next troubleshooting step?
[update 2011-feb-12] I followed the procedure outlined at Which to use NFS or Samba?. I've now verified that my server export is working because I can mount the nfs shares via /etc/fstab. Here is my config, server side:
/home/matt      192.168.1.0/255.255.255.0(rw,sync,no_subtree_check)
/home/shared    192.168.1.0/255.255.255.0(rw,sync,no_subtree_check)
And in client /etc/fstab:
ubuntu-server:/home/matt  /nfs/matt  nfs rw,hard,intr 0 0
ubuntu-server:/home/shared  /nfs/shared  nfs rw,hard,intr 0 0
followed by sudo mount /nfs/shared. (I also needed to add an entry to /etc/hosts so the server name would resolve to ip)
matt wilkie
  • 2,250
If your server name is ubuntu-server, /nfs/tutu where to mount the nfs share, then in /etc/auto.nfs:
tutu -fstype=nfs4 ubuntu-server:/
and then run:
sudo invoke-rc.d autofs restart
ls /nfs/tutu
matt wilkie
  • 2,250
LionelR
  • 136
Here's my auto.master file for reference :
/etc/auto.master
+auto.master
/smb /etc/auto.smb uid=1000,gid=1000,--timeout=300 --ghost
For my samba share, that's all I need to do to see my shares listed :
scaine@GroovyTosh:~$ ls /smb/core
Archive  Backups  Data  Live
Due to a bug in smbclient, I have to specify the UID and GID. The timeout is how long before autofs unmounts an unused share and the ghost option keeps previously created folders in place inside /smb even when the share is not available.
I can also browse my /smb by IP address (e.g. ls /smb/192.168.1.10).
In your case, you might want to try the /net option, instead of manually specifying your exports. So your auto.master would simply be :
+auto.master
/net /etc/auto.net --timeout=300 --ghost
Then after a sudo service autofs restart, try ls /net.
Scaine
  • 11,229
