I have some errors with the upgrade. Any ideas how to fix it? This is what I am getting:
cata@cata-MINI-S:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
libigsc0 : Depends:
but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
cata@cata-MINI-S:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
blender-data fonts-dejavu fonts-dejavu-extra gdal-data gdal-plugins libaec0 libarmadillo12 libarpack2t64 libavdevice60 libblosc1 libboost-iostreams1.83.0
libboost-locale1.83.0 libboost-thread1.83.0 libcfitsio10t64 libcharls2 libdc1394-25 libdcmtk17t64 libembree4-4 libfreexl1 libfyba0t64 libgdal34t64
libgdcm3.0t64 libgeos-c1t64 libgeos3.12.1t64 libgeotiff5 libhdf4-0-alt libhdf5-103-1t64 libhdf5-hl-100t64 libhwloc-plugins libhwloc15 libjemalloc2
libkmlbase1t64 libkmldom1t64 libkmlengine1t64 libllvm17t64 liblog4cplus-2.0.5t64 libmetee libminizip1t64 libmysqlclient21 libnetcdf19t64 libodbc2
libodbcinst2 libogdi4.1 libopencolorio2.1t64 libopencv-core406t64 libopencv-imgcodecs406t64 libopencv-imgproc406t64 libopencv-videoio406t64
libopenimageio2.4t64 libopenvdb10.0t64 libosdcpu3.5.0t64 libosdgpu3.5.0t64 libpq5 libproj25 libpugixml1v5 libpystring0 libqhull-r8.0 librttopo1
libsocket++1 libspatialite8t64 libspnav0 libsuperlu6 libsz2 libtbb12 libtbbbind-2-5 libtbbmalloc2 liburiparser1 libxerces-c3.2t64 libxnvctrl0
libyaml-cpp0.8 linux-headers-6.11.0-19-generic linux-hwe-6.11-headers-6.11.0-19 linux-hwe-6.11-tools-6.11.0-19 linux-image-6.11.0-19-generic
linux-modules-6.11.0-19-generic linux-modules-extra-6.11.0-19-generic linux-tools-6.11.0-19-generic mysql-common proj-bin proj-data python3-netifaces
unixodbc-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libmetee-dev
The following NEW packages will be installed:
libmetee-dev
0 upgraded, 1 newly installed, 0 to remove and 42 not upgraded.
2 not fully installed or removed.
Need to get 0 B/114 kB of archives.
After this operation, 666 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 237936 files and directories currently installed.)
Preparing to unpack .../libmetee-dev_4.3.0-0ubuntu1~24.04~ppa1_amd64.deb ...
Unpacking libmetee-dev:amd64 (4.3.0-0ubuntu1~24.04~ppa1) ...
dpkg: error processing archive /var/cache/apt/archives/libmetee-dev_4.3.0-0ubuntu1~24.04~ppa1_amd64.deb (--unpack):
trying to overwrite '/usr/share/doc/metee/html/annotated.html', which is also in package libmetee 4.1.0+88~u24.04
cata@cata-MINI-S:~$
cata@cata-MINI-S:~$ apt policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://security.ubuntu.com/ubuntu noble-security/restricted amd64 Packages
release v=24.04,o=Ubuntu,a=noble-security,n=noble,l=Ubuntu,c=restricted,b=amd64
origin security.ubuntu.com
500 http://security.ubuntu.com/ubuntu noble-security/multiverse amd64 Packages
release v=24.04,o=Ubuntu,a=noble-security,n=noble,l=Ubuntu,c=multiverse,b=amd64
500 http://security.ubuntu.com/ubuntu noble-security/universe amd64 Packages
release v=24.04,o=Ubuntu,a=noble-security,n=noble,l=Ubuntu,c=universe,b=amd64
500 http://security.ubuntu.com/ubuntu noble-security/main amd64 Packages
release v=24.04,o=Ubuntu,a=noble-security,n=noble,l=Ubuntu,c=main,b=amd64
100 https://mirrors.nav.ro/ubuntu noble-backports/universe amd64 Packages
release v=24.04,o=Ubuntu,a=noble-backports,n=noble,l=Ubuntu,c=universe,b=amd64
origin mirrors.nav.ro
100 https://mirrors.nav.ro/ubuntu noble-backports/main amd64 Packages
release v=24.04,o=Ubuntu,a=noble-backports,n=noble,l=Ubuntu,c=main,b=amd64
500 https://mirrors.nav.ro/ubuntu noble-updates/restricted amd64 Packages
release v=24.04,o=Ubuntu,a=noble-updates,n=noble,l=Ubuntu,c=restricted,b=amd64
500 https://mirrors.nav.ro/ubuntu noble-updates/multiverse amd64 Packages
release v=24.04,o=Ubuntu,a=noble-updates,n=noble,l=Ubuntu,c=multiverse,b=amd64
500 https://mirrors.nav.ro/ubuntu noble-updates/universe amd64 Packages
release v=24.04,o=Ubuntu,a=noble-updates,n=noble,l=Ubuntu,c=universe,b=amd64
500 https://mirrors.nav.ro/ubuntu noble-updates/main amd64 Packages
release v=24.04,o=Ubuntu,a=noble-updates,n=noble,l=Ubuntu,c=main,b=amd64
500 https://mirrors.nav.ro/ubuntu noble/restricted amd64 Packages
release v=24.04,o=Ubuntu,a=noble,n=noble,l=Ubuntu,c=restricted,b=amd64
500 https://mirrors.nav.ro/ubuntu noble/multiverse amd64 Packages
release v=24.04,o=Ubuntu,a=noble,n=noble,l=Ubuntu,c=multiverse,b=amd64
500 https://mirrors.nav.ro/ubuntu noble/universe amd64 Packages
release v=24.04,o=Ubuntu,a=noble,n=noble,l=Ubuntu,c=universe,b=amd64
500 https://mirrors.nav.ro/ubuntu noble/main amd64 Packages
release v=24.04,o=Ubuntu,a=noble,n=noble,l=Ubuntu,c=main,b=amd64
500 https://repositories.intel.com/gpu/ubuntu noble/client i386 Packages
release n=noble,c=client,b=i386
origin repositories.intel.com
500 https://repositories.intel.com/gpu/ubuntu noble/client amd64 Packages
release n=noble,c=client,b=amd64
500 https://repositories.intel.com/gpu/ubuntu jammy/client i386 Packages
release n=jammy,c=client,b=i386
500 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 Packages
release n=jammy,c=client,b=amd64
Pinned packages:
cata@cata-MINI-S:~$
