When I attempt an elevated apt update I am getting the following errors:
Get:1 http://security.ubuntu.com/ubuntu noble-security InRelease [126 kB]
Err:1 http://security.ubuntu.com/ubuntu noble-security InRelease
  Error writing to file - write (28: No space left on device) [IP: 185.125.190.82 80]
Get:4 http://mt.archive.ubuntu.com/ubuntu noble-updates InRelease [126 kB]
Err:4 http://mt.archive.ubuntu.com/ubuntu noble-updates InRelease
  Error writing to file - write (28: No space left on device) [IP: 193.206.214.14 80]
Get:5 http://mt.archive.ubuntu.com/ubuntu noble-backports InRelease [126 kB]
Err:5 http://mt.archive.ubuntu.com/ubuntu noble-backports InRelease
Get:6 https://esm.ubuntu.com/apps/ubuntu noble-apps-security InRelease [7,595 B]
Err:6 https://esm.ubuntu.com/apps/ubuntu noble-apps-security InRelease
  Error writing to file - write (28: No space left on device) [IP: 91.189.91.47 443]
Get:7 https://esm.ubuntu.com/apps/ubuntu noble-apps-updates InRelease [7,480 B]
Err:7 https://esm.ubuntu.com/apps/ubuntu noble-apps-updates InRelease
Get:8 https://esm.ubuntu.com/infra/ubuntu noble-infra-security InRelease [7,474 B]
Err:8 https://esm.ubuntu.com/infra/ubuntu noble-infra-security InRelease
Get:9 https://esm.ubuntu.com/infra/ubuntu noble-infra-updates InRelease [7,473 B]
Err:9 https://esm.ubuntu.com/infra/ubuntu noble-infra-updates InRelease
Reading package lists... Done
Building dependency tree... Done
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://mt.archive.ubuntu.com/ubuntu noble InRelease: Splitting up /var/lib/apt/lists/mt.archive.ubuntu.com_ubuntu_dists_noble_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://downloads.plex.tv/repo/deb public InRelease: Splitting up /var/lib/apt/lists/downloads.plex.tv_repo_deb_dists_public_InRelease into data and signature failed
W: Failed to fetch https://downloads.plex.tv/repo/deb/dists/public/InRelease  Splitting up /var/lib/apt/lists/downloads.plex.tv_repo_deb_dists_public_InRelease into data and signature failed
W: Failed to fetch https://esm.ubuntu.com/apps/ubuntu/dists/noble-apps-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 91.189.91.47 443]
W: Failed to fetch https://esm.ubuntu.com/apps/ubuntu/dists/noble-apps-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 91.189.91.47 443]
W: Failed to fetch https://esm.ubuntu.com/infra/ubuntu/dists/noble-infra-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 91.189.91.47 443]
W: Failed to fetch https://esm.ubuntu.com/infra/ubuntu/dists/noble-infra-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 91.189.91.47 443]
W: Failed to fetch http://mt.archive.ubuntu.com/ubuntu/dists/noble/InRelease  Splitting up /var/lib/apt/lists/mt.archive.ubuntu.com_ubuntu_dists_noble_InRelease into data and signature failed
W: Failed to fetch http://mt.archive.ubuntu.com/ubuntu/dists/noble-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 193.206.214.14 80]
W: Failed to fetch http://mt.archive.ubuntu.com/ubuntu/dists/noble-backports/InRelease  Error writing to file - write (28: No space left on device) [IP: 193.206.214.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/noble-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 185.125.190.82 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
The IP addresses are not mine.
A df tells me that /dev/mapper/ubuntu--vg-ubuntu--lv 102626232 98428892 0 100% /
If this is the cause of the problem can I clear it to make more space? (will rm work?)
----------------- added information
The drive is 500G and the output of df -l is shown below:
hmeadmin@vm-plex:~$ df -l
Filesystem                        1K-blocks     Used Available Use% Mounted on
tmpfs                               1637572     1060   1636512   1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv 102626232 98436808         0 100% /
tmpfs                               8187856        4   8187852   1% /dev/shm
tmpfs                                  5120        0      5120   0% /run/lock
/dev/sda2                           1992552   189288   1682024  11% /boot
tmpfs                               1637568       12   1637556   1% /run/user/1000
hmeadmin@vm-plex:~$ lsblk
NAME                      MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
loop0                       7:0    0 11.5M  1 loop /snap/canonical-livepatch/316
loop1                       7:1    0 73.9M  1 loop /snap/core22/1963
loop2                       7:2    0 50.9M  1 loop /snap/snapd/24505
sda                         8:0    0  500G  0 disk
├─sda1                      8:1    0    1M  0 part
├─sda2                      8:2    0    2G  0 part /boot
└─sda3                      8:3    0  498G  0 part
  └─ubuntu--vg-ubuntu--lv 252:0    0  100G  0 lvm  /
sr0                        11:0    1    3G  0 rom
hmeadmin@vm-plex:~$ sudo parted -l
[sudo] password for hmeadmin:
Model: QEMU QEMU HARDDISK (scsi)
Disk /dev/sda: 537GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags 1 1049kB 2097kB 1049kB bios_grub 2 2097kB 2150MB 2147MB ext4 3 2150MB 537GB 535GB
Model: Linux device-mapper (linear) (dm) Disk /dev/mapper/ubuntu--vg-ubuntu--lv: 107GB Sector size (logical/physical): 512B/512B Partition Table: loop Disk Flags:
Number Start End Size File system Flags 1 0.00B 107GB 107GB ext4
Warning: Unable to open /dev/sr0 read-write (Read-only file system). /dev/sr0 has been opened read-only. Error: /dev/sr0: unrecognised disk label Model: QEMU QEMU DVD-ROM (scsi) Disk /dev/sr0: 3213MB Sector size (logical/physical): 2048B/2048B Partition Table: unknown Disk Flags:
muru
  • 207,228
chribonn
  • 311
