I am trying to install Openfoam on Ubuntu (WSL2) My wsl installation is fine. I have no issues with that. Followed the guide to install Openfoam: Step 1:
curl -s https://dl.openfoam.com/add-debian-repo.sh | sudo bash
O/P:
Detected distribution code-name: noble
Overwrote /etc/apt/sources.list.d/openfoam.list
Importing openfoam gpg key... done
Overwrote /etc/apt/trusted.gpg.d/openfoam.gpg
Running apt-get update... done
The repository is setup! You can now install packages.
Step 2:
sudo apt-get install openfoam2412-default
O/P:
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package openfoam2412-default
I tried to update:
sudo apt-get update
O/P:
Ign:1 https://sourceforge.net/projects/openfoam/files/repos/deb noble InRelease
Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
Err:1 https://sourceforge.net/projects/openfoam/files/repos/deb noble InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 104.18.12.149 443]
Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
W: Failed to fetch https://dl.openfoam.com/repos/deb/dists/noble/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 104.18.12.149 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
I tried to also do:
sudo apt-get install ca-certificates
O/P:
ca-certificates is already the newest version (20240203).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Has anyone else encountered this issue? any help is appreciated. Thank you
