Restart your PC, this can be done mostly by holding down the Power button for a time. Press Esc, Shift or F10 at startup. If this doesn't work, then: Ctrl - Alt - F2, login and: startx. If this doesn't work, if you still have your Live USB, check if you have "Boot Repair" in Apps. If not, Ctrl-Alt-T and: sudo add-apt-repository ppa:yannubuntu/boot-repair sudo apt update sudo apt install -y boot-repair. Start Boot Repair and generate a report, don't need to upload to a pastebin. Read the last lines. They should say what a repair will perform. If you are OK with that, start a "Recommended Repair", which solves a lot of problems. Top right, Power, Reboot. Remove the live USB and Enter. Try again, the blinking cursor should be gone.
