I have created a usb bootup stick for 10.10, and reduced the timeout to 0 sec... but after it boots up it shows two options either to install or try ubuntu... I want to avoid this screen and directly go to the tryout mode...
at the first screen at bootup if I press any key,there is an option to select "try Ubuntu without installing",in this case I go to tryout mode directly... I want this behaviour without pressing any key...
any suggestions???
Thanks.
I'm not really sure what you want, but if you want it to behave this way you should install Ubuntu on the usb disk rather than installing the Live-CD on it.
I don't know if it is a solution but I think it can get close to what you want.
Make a new Ubuntu install and then, without installing anything, put it back on the usb stick using Remastersys (http://en.wikipedia.org/wiki/Remastersys).
Done that you should be able to boot into your Ubuntu from the usb stick without choosing to try or install :)
If Remastersys doesn't do the trick as you want it just a plain install ON the usb stick could work too.
Pitto
  • 1,978
Solution!
use LiLi to create your USB key!
When you create the USB disk using Unetbootin, there won't be a "Try Ubuntu / Install Ubuntu" screen after booting.
I don't know why this difference exists between Unetbootin and Startup Disk creator, but I just tested this (see my question).
This makes bootup much faster in total.
