Both Ubuntu 22.04 and 24.04 have rustc 1.75, with additional versions up to 1.80 in packages like rustc-1.77. Rust 1.81 is not available from the official repository of any LTS version (only oracular and newer).
Rust 1.80 was released in July 2024, not long after 24.03 itself was released. I would have naively expected the base rustc package to be newer in 24.04, and/or the additional packages in 24.04 to go on until July 2026, but that doesn't seem to be the case.
This situation where one LTS release got new versions of the language multiple times over two years, and the other basically never had any update, is more than a bit confusing. I would like to understand if there's some kind of policy for introducing new versions of rustc in Ubuntu LTS releases, so that I can plan which Rust features to use for software that wants to be buildable on Ubuntu 24.04, and when.
Once a release is stable and actually released (eg. Ubuntu questing will be released to Ubuntu 25.10), standard SRU policies apply.
Refer https://documentation.ubuntu.com/sru/en/latest/
For new packages refer to the instructions under heading "NEW queue in the SRU context" which states
The SRU policy does not forbid uploading a new source or binary to active releases. But if that happens it needs double approval...
guiverc
  • 33,561
Canonical used to package julia, but they stopped for the same reason and replaced it with the julia snap package. Perhaps the same can be done for rust.
Don't use the official repositories. Instead, use rustup to manage rust versions.
Use the following command to install rustup.
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
