I know Incus runs rootless containers, so this is a bit superfluous, but I'm trying to run rootless Podman containers from inside an Incus system container and I've hit an issue. I get this error when I try podman run as non-root:
cannot clone: Permission denied
Error: cannot re-exec process
If I run podman info with debug, I get:
podman info --log-level=DEBUG
DEBU[0000] Using OCI runtime "/usr/bin/crun"
DEBU[0000] systemd-logind: Unknown object '/'.
DEBU[0000] Invalid systemd user session for current user
DEBU[0000] Shutting down engines
So it seems to be an issue relating to a systemd session. From what I can see, my user does have a session:
$ env | grep XDG
XDG_SESSION_TYPE=tty
XDG_SESSION_CLASS=user
XDG_SESSION_ID=c8
XDG_RUNTIME_DIR=/run/user/1000
$ sudo loginctl SESSION UID USER SEAT TTY STATE IDLE SINCE c2 1000 ubuntu - pts/1 active no - 1 sessions listed.
My versions are:
  • Incus host OS version: Ubuntu 24.04.2 LTS
  • Incus version: 6.12
  • Incus Ubuntu system container version: ubuntu/24.04/cloud (24.04.2 LTS)
  • Podman version: 4.9.3
The steps to reproduce are:
1) Create Incus system container and enable security.nesting for running continaers inside of system containers (as per Incus docs)
$ incus init images:ubuntu/24.04/cloud scratcher -d eth0,ipv4.address=172.30.10.13
$ incus config set scratcher security.nesting true
$ incus start scratcher
2) Exec to the Incus system container with a login session
$ incus exec scratcher -- sudo --login --user ubuntu
$ sudo apt update && sudo apt upgrade -y
3) Install and configure Podman as per the Podman docs
$ sudo apt install podman -y
$ sudo usermod --add-subuids 165536-231072 --add-subgids 165536-231072 ubuntu
4) Run a rootful container - it works
$ sudo podman run --rm docker.io/hello-world | head -n3
Hello from Docker! This message shows that your installation appears to be working correctly.
5) Run a rootless container - it fails
$ podman run --rm docker.io/hello-world
Please, I'd really like to know what is causing the issue, and if there is a solution?
cjt
  • 163
OP have you tried asking what/why the error on the Incus User Forum? I know the devs do Q&A every day maybe 1 of them can give you a hint as to cause? – bmullan Commented 25 secs ago
bmullan
  • 784
