I'm trying to allow a Bash script to run with sudo privileges (and without asking for the password) by editing the /etc/sudoers file with sudo visudo and placing ALL ALL = (root) NOPASSWD: /home/myUserName/scriptName in the last line of the file (since I know that the order in the /etc/sudoers file matters). However, it doesn't work. If it matters, I am running Kubuntu 24.04 LTS.
My full /etc/sudoers file as given by sudo visudo is:
  GNU nano 7.2                            /etc/sudoers.tmp
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap>
This fixes CVE-2005-4890 and possibly breaks some versions of kdesu
(#1011624, https://bugs.kde.org/show_bug.cgi?id=452532)
Defaults use_pty
This preserves proxy settings from user environments of root
equivalent users (group sudo)
#Defaults:%sudo env_keep += "http_proxy https_proxy ftp_proxy all_proxy no_proxy"
This allows running arbitrary commands, but so does ALL, and it means
different sudoers have their choice of editor respected.
#Defaults:%sudo env_keep += "EDITOR"
Completely harmless preservation of a user preference.
#Defaults:%sudo env_keep += "GREP_COLOR"
While you shouldn't normally run git as root, you need to with etckeeper
#Defaults:%sudo env_keep += "GIT_AUTHOR_* GIT_COMMITTER_*"
Per-user preferences; root won't have sensible values for them.
#Defaults:%sudo env_keep += "EMAIL DEBEMAIL DEBFULLNAME"
"sudo scp" or "sudo rsync" should be able to use your SSH agent.
#Defaults:%sudo env_keep += "SSH_AGENT_PID SSH_AUTH_SOCK"
Ditto for GPG agent
#Defaults:%sudo env_keep += "GPG_AGENT_INFO"
Host alias specification
User alias specification
Cmnd alias specification
User privilege specification
root ALL=(ALL:ALL) ALL
Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL
See sudoers(5) for more information on "@include" directives:
@includedir /etc/sudoers.d
Importantly, since the only command (requiring sudo to succeed) that scriptName itself utilizes is dash ..., I also thought to try adding ALL ALL = (root) NOPASSWD: /usr/bin/dash, and it works. However, dash is quite a powerful command widely used elsewhere, so I am looking for an option to allow only the script itself to run as sudo.
Removing the option to prompt for a password for every action is extremely dangerous.
It can be done, assuming the risks involved.
Edit the /etc/sudoers file with visudo:
We must write the username. To be verbose, we search for the block:
# User privilege specification
And we write:
myUserName ALL=(ALL) NOPASSWD:ALL
To limit this to only one command, specify it with:
myUserName ALL=(ALL) NOPASSWD:/home/myUserName/scriptName
kyodake
  • 17,808
The script contents could be overwritten and afterwards execute arbitrary commands without a password, use this method only if you are aware of the risks.
Make sure that the script used is in one of the secure paths of sudo (from /etc/sudoers):
## Use a hard-coded PATH instead of the user's to find commands.
## This also helps prevent poorly written scripts from running
## arbitrary commands under sudo.
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/bin"
  1. Create a new entry 95-sudoscript in the /etc/sudoers.d directory with visudo:
# This script runs under `sudo` without the need of a password
tiredUser ALL=(root) NOPASSWD:/usr/local/bin/script_name
If possible, restrict to a single user running the script.
Save your script script_name to /usr/local/bin/. Now the script /usr/local/bin/script_name can be executed with sudo script_name without password.
This was tested under Kubuntu 25.04 with
Sudo version 1.9.16p2
Sudoers policy plugin version 1.9.16p2
Sudoers file grammar version 50
Sudoers I/O plugin version 1.9.16p2
Sudoers audit plugin version 1.9.16p2
emk2203
  • 4,393
  • 26
  • 52
