Midnight Commander 3.4.8.1 > File Find. What text do I have to put in the »Content:« text field and in the other fields? I tried several settings in the other fields but mc always returned no result. (This is not explained in 'man mc'.) My hope is to perform some grep-like action using mc. http://svn.dd-wrt.com:8000/browser//src/router/mc2/src/filemanager/find.c did not enlighten me.
Asked
Active
Viewed 1,392 times
I managed now to obtain meaningful results. I probably always had set the mask in the »File Name:« text field too narrow. I set it now to '*', and now it works. I asserted also »Use Shell Pattern«, »Search for Contents« and »Case«.
user43816
- 263
- 1
- 4
- 17
You must compelte all the fields that are required for a complete search. You must tell mc everything, like:
- where to search (start at)
- file name (what file you are looking for; here you can use wildcards like
*) - what is inside that file you are intersted in (content)
The output of the search will be like: no:filename where:
nois the number of the line in the file where your content was found.filenameis the name of the file find by search according to your parameters from "Start at" and "File name."
Eliah Kagan
- 119,640
Bulix
- 1
