I was trying to follow this steps
# Setup the repository
Install the public key for the repository (if not done previously):
curl -fsS https://www.pgadmin.org/static/packages_pgadmin_org.pub | sudo gpg --dearmor -o /usr/share/keyrings/packages-pgadmin-org.gpg
Create the repository configuration file:
sudo sh -c 'echo "deb [signed-by=/usr/share/keyrings/packages-pgadmin-org.gpg] https://ftp.postgresql.org/pub/pgadmin/pgadmin4/apt/$(lsb_release -cs) pgadmin4 main" > /etc/apt/sources.list.d/pgadmin4.list && apt update'
Install pgAdmin
Install for both desktop and web modes:
sudo apt install pgadmin4
Install for desktop mode only:
sudo apt install pgadmin4-desktop
Install for web mode only:
sudo apt install pgadmin4-web
Configure the webserver, if you installed pgadmin4-web:
sudo /usr/pgadmin4/bin/setup-web.sh
but when I run the second one (sudo sh ...) in the terminal this comes out
E: Conflicting values set for option Signed-By regarding source https://apt.postgresql.org/pub/repos/apt/ noble-pgdg: /usr/share/postgresql-common/pgdg/apt.postgresql.org.asc != /usr/share/postgresql-common/pgdg/apt.postgresql.org.gpg
E: The list of sources could not be read.
someone knows what can I do?
