I'm encountering an issue using the autoinstall feature on Ubuntu Server 22.04 LTS. My goal is to deploy a system with a custom storage layout, but the autoinstall process fails during the storage configuration phase. I’m using the following YAML snippet for the configuration:
grub:
  reorder_uefi: false
storage: config: # Initialize disk and BIOS GRUB partition - grub_device: true id: disk-sda path: /dev/sda ptable: gpt type: disk wipe: superblock-recursive - device: disk-sda flag: bios_grub id: grub-part number: 1 size: 1M type: partition
# EFI System Partition
- device: disk-sda
  number: 2
  type: partition
- fstype: fat32
  type: format
  volume: efi-part
- device: efi-fs
  path: /boot/efi
  type: mount
# 4 GB swap partition
- device: disk-sda
  number: 3
  type: partition
- fstype: swap
  type: format
  volume: swap-part
- device: swap-fs
  path: none
  type: mount
# 100 GB root partition
- device: disk-sda
  number: 4
  type: partition
- fstype: ext4
  type: format
  volume: root-part
- device: root-fs
  path: /
  type: mount
# 50 GB home partition
- device: disk-sda
  number: 5
  type: partition
- fstype: ext4
  type: format
  volume: home-part
- device: home-fs
  path: /home
  type: mount
I have verified that /dev/sda is correct for the target disk, and I specifically configured both a BIOS GRUB (with a bios_grub partition) and an EFI System partition. Despite that, the installer does not complete successfully and stops during the storage configuration step.
Any insights, tips, or suggestions would be greatly appreciated.
Edit: I've verified that the rest of my autoinstall file works perfectly by just using:
storage:
  layout:
However, I want to specifically configure the storage to the above configuration.
glitchbox
  • 23
You're missing a few configuration keys.
In the EFI section you need to set flag: boot and grub_device: true as follows:
    - device: disk-sda
      number: 2
      type: partition
      flag: boot
      grub_device: true
    - fstype: fat32
      type: format
      volume: efi-part
    - device: efi-fs
      path: /boot/efi
      type: mount
For the swap partition, you need to set flag: swap:
    - device: disk-sda
      number: 3
      type: partition
      flag: swap
    - fstype: swap
      type: format
      volume: swap-part
    - device: swap-fs
      path: none
      type: mount
mpboden
  • 3,046
