120
I use the dpkg -l command to find out what version of a package I have installed. For example:
dpkg -l network-manager
returns the information on the package:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                      Version                   Description
ii  network-manager           0.8.3~git.20101118t223039 network management framework daemon
As you can see, it returns 0.8.3~git.20101118t223039 which is wrong because it truncates the version (I've picked a long one for the purpose of this question). The way I've solved this in the past is to pass a stupidly long COLUMNS argument to make it expand:
COLUMNS=200 dpkg -l network-manager
which gives me the entire version number, but also a bunch of junk:
ii  network-manager                              0.8.3~git.20101118t223039.d60a988-0ubuntu1   network management framework daemon
Now I can see the full version number, which is 0.8.3~git.20101118t223039.d60a988-0ubuntu1.
I get the feeling that this is not the proper way to find the version number of an installed package. This never really was a problem in the past, but with the tacking on of "ubuntu" in the versions and the proliferation of PPAs these strings are getting longer and longer. Is there an easier way?
Jorge Castro
  • 73,717
6 Answers6
112
dpkg -s <packagename> | grep '^Version:'
e. g.:
dpkg -s network-manager | grep '^Version:'
Sample output:
Version: 0.8.1+git.20100810t184654.ab580f4-0ubuntu2
David Foerster
  • 36,890
  • 56
  • 97
  • 151
aneeshep
  • 30,949
77
dpkg-query --showformat='${Version}' --show python3-lxml
A T
  • 2,578
26
It's not using the dpkg command but apt-show-versions Install banshee
Example:
$ apt-show-versions network-manager
network-manager/maverick uptodate 0.8.1+git.20100810t184654.ab580f4-0ubuntu2
Isaiah
  • 60,750
17
I think aneeshep's is the best answer as your question specifies using dpkg. But for completeness sake, here's another way:
apt-cache policy network-manager
network-manager:
  Installed: 0.8.1+git.20100810t184654.ab580f4-0ubuntu2
  Candidate: 0.8.1+git.20100810t184654.ab580f4-0ubuntu2
  Version table:
 *** 0.8.1+git.20100810t184654.ab580f4-0ubuntu2 0
        500 http://us.archive.ubuntu.com/ubuntu/ maverick/main i386 Packages
        100 /var/lib/dpkg/status
Or for just the version number:
apt-cache policy network-manager | grep 'Installed:' | cut -c 14-
Another method to find the version of an installed package via dpkg as below,
dpkg -l | awk '$2=="package-name" { print $3 }'
Example:
$ dpkg -l | awk '$2=="network-manager" { print $3 }'
0.9.8.0-0ubuntu22
Explanation:
dpkg -l command lists all the installed packages.This standard output was fed as input to the awk command.awk searches for the corresponding package name in the standard input(column 2) if it finds then it grabs the corresponding line. And finally prints the value of (column 3) which was actually represents the package version.
$ dpkg -l
||/ Name           Version      Architecture Description
According to the above, column 2 represents the package name, column 3 represents the package version, column 4 represents the architecture and column 5 represents package description.
tanius
  • 6,610
  • 42
  • 52
Avinash Raj
  • 80,446
The command apt -qq list <package-name> shows whether the package is installed and appears to return the full version number.
Example 1 – uses -qq
$ apt -qq list network-manager
network-manager/now 1.10.14-0ubuntu2 amd64 [installed,local]
Example 2 – uses -qq and *
$ apt -qq list virtualbox-6*
virtualbox-6.0/unknown 6.0.24-139119~Ubuntu~bionic amd64
virtualbox-6.1/unknown,now 6.1.16-140961~Ubuntu~bionic amd64 [installed]
Example 3 – uses -qqa
$ apt -qqa list keepassxc
keepassxc/bionic,now 2.6.2-1ppa1~bionic1 amd64 [installed]
keepassxc/bionic 2.3.1+dfsg.1-1 amd64
Daniel C
  • 4,170
