I've been trying to install Ubuntu Server 24.04.2 (ubuntu-24.04.2-live-server-ppc64el.iso) onto an IBM Power S922 (9009-22G) that I bought second hand.
I checked the compatibility for my machine as stated here (https://www.ibm.com/docs/en/linux-on-systems?topic=lpo-linux-distributions-virtualization-options-power8-power9-linux-power-systems#liaamdistros__table_i11_l3f_1cc) and I am installing under PowerVM LPARs configuration and the machine firmware is properly configured.
I am following the procedure described on the IBM documentation here (https://www.ibm.com/docs/en/linux-on-systems?topic=ilps-installing-linux-power-systems-servers-by-using-serial-console) to install via the serial console, since the machine does not have a graphic card.
The only difference is that I am using a bootable USB stick with the Ubuntu iso flashed onto it.
The machine has a preinstalled Red Hat Enterprise installation that I would like to wipe while installing Ubuntu since I do not own the license.
Right after booting, I get a kernel panic error, as shown below:
IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM IBM
IBM IBM IBM IBM IBM IBM IBM    STARTING SOFTWARE    IBM IBM IBM IBM IBM IBM IBM
IBM IBM IBM IBM IBM IBM IBM       PLEASE WAIT...    IBM IBM IBM IBM IBM IBM IBM
Elapsed time since release of system processors: 2 mins 47 secs
Welcome to GRUB!
error: unrecognized number.
                         GNU GRUB  version 2.12
 |*Try or Install Ubuntu Server                                               |
 | Ubuntu Server with the HWE kernel                                          |
  Use the ^ and v keys to select which entry is highlighted.
  Press enter to boot the selected OS, `e' to edit the commands
  before booting or `c' for a command-line.
OF stdout device is: /vdevice/vty@30000000
Preparing to boot Linux version 6.8.0-53-generic (buildd@bos03-ppc64el-041) (powerpc64le-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubun 17 15:29:57 UTC 2025 (Ubuntu 6.8.0-53.55-generic 6.8.12)
Detected machine type: 0000000000000101
command line: BOOT_IMAGE=/casper/vmlinux quiet ---
Max number of cores passed to firmware: 256 (NR_CPUS = 2048)
Calling ibm,client-architecture-support... done
memory layout at init:
  memory_limit : 0000000000000000 (16 MB aligned)
  alloc_bottom : 0000000014430000
  alloc_top    : 0000000020000000
  alloc_top_hi : 0000000020000000
  rmo_top      : 0000000020000000
  ram_top      : 0000000020000000
instantiating rtas at 0x000000001ec90000... done
prom_hold_cpus: skipped
copying OF device tree...
Building dt strings...
Building dt structure...
Device tree strings 0x0000000014440000 -> 0x0000000014441a0f
Device tree struct  0x0000000014450000 -> 0x0000000014470000
[    2.636172] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[    2.636188] CPU: 49 PID: 1 Comm: init Not tainted 6.8.0-53-generic #55-Ubuntu
[    2.636195] Hardware name: IBM,9009-22G POWER9 (architected) 0x4e0203 0xf000005 of:IBM,FW950.11 (VL950_075) hv:phyp pSeries
[    2.636202] Call Trace:
[    2.636205] [c00000000954fa30] [c0000000016c85f8] dump_stack_lvl+0xe0/0x10c (unreliable)
[    2.636218] [c00000000954fa60] [c000000000192aec] panic+0x300/0x524
[    2.636226] [c00000000954fb00] [c00000000019e048] do_exit+0x5b8/0x5ec
[    2.636234] [c00000000954fba0] [c00000000019e264] do_group_exit+0x4c/0xbc
[    2.636243] [c00000000954fbe0] [c00000000019e2fc] pid_child_should_wake+0x0/0x11c
[    2.636252] [c00000000954fc00] [c000000000033308] system_call_exception+0xf8/0x290
[    2.636260] [c00000000954fe50] [c00000000000d05c] system_call_vectored_common+0x15c/0x2ec
[    2.636269] --- interrupt: 3000 at 0x7b40d4529914
[    2.636274] NIP:  00007b40d4529914 LR: 00007b40d4529914 CTR: 0000000000000000
[    2.636280] REGS: c00000000954fe80 TRAP: 3000   Not tainted  (6.8.0-53-generic)
[    2.636286] MSR:  800000000280f033 <SF,VEC,VSX,EE,PR,FP,ME,IR,DR,RI,LE>  CR: 42002848  XER: 00000000
[    2.636304] IRQMASK: 0
[    2.636304] GPR00: 00000000000000ea 00007ffffbf63b50 00007b40d4686d00 0000000000000001
[    2.636304] GPR04: 0000000000000000 00007ffffbf63d50 00007ffffbf63d60 000004ebf32cd3e0
[    2.636304] GPR08: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[    2.636304] GPR12: 0000000000000000 00007b40d473a640 0000000000000000 0000000000000000
[    2.636304] GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[    2.636304] GPR20: 0000000000000000 0000000000000000 0000000000000000 000004ebd5abb6f4
[    2.636304] GPR24: 00007b40d472f458 00007b40d4730000 00007ffffbf646f8 0000000000000003
[    2.636304] GPR28: 00007ffffbf646d8 00007b40d4733650 fffffffffffff000 0000000000000001
[    2.636368] NIP [00007b40d4529914] 0x7b40d4529914
[    2.636372] LR [00007b40d4529914] 0x7b40d4529914
[    2.636377] --- interrupt: 3000
[    2.642259] pstore: backend (nvram) writing error (-1)
[    2.647645] Rebooting in 10 seconds..
What I already tried to solve this error and nothing changed:
- Added boot parameters to the grub boot command line: inst.headless console=ttys0 crashkernel=auto efi_pstore.pstore_disable=1
 - Tried with Ubuntu Server 24.10 -> Same error
 - Tried with Ubuntu Server 22.04 -> Kernel Panic, error "unable to open console"
 - Tried with another USB key (up to 64GB)
What am I doing wrong? What can I do to properly boot the Ubuntu Server install ?
Thank you in advance for your help
Kind regards
