Yesterday my server still OK, but today after try to sudo apt-get update i got this error: update process.
I try: sudo rm /var/lib/apt/lists/* -vf And got This.Then try update again, but it's not solving my problem then show May be still same error.
I checked my internet connection try ping google.com, get result :
PING google.com (74.125.235.40) 56(84) bytes of data.
From 136.198.117.254: icmp_seq=1 Redirect Network(New nexthop: fw1.jvc-jein.co.id (136.198.117.6))
64 bytes from sin01s05-in-f8.1e100.net (74.125.235.40): icmp_req=1 ttl=53 time=20.6 ms
64 bytes from sin01s05-in-f8.1e100.net (74.125.235.40): icmp_req=2 ttl=53 time=18.2 ms
64 bytes from sin01s05-in-f8.1e100.net (74.125.235.40): icmp_req=3 ttl=53 time=33.0 ms
64 bytes from sin01s05-in-f8.1e100.net (74.125.235.40): icmp_req=4 ttl=53 time=30.0 ms
64 bytes from sin01s05-in-f8.1e100.net (74.125.235.40): icmp_req=5 ttl=53 time=28.1 ms
In some sites said that may be it caused by getdeb server is down.
try to install:
jeinqa@SVRQAR:~$ sudo apt-get install pastebinit
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_precise-security_restricted_binary-amd64_Packages
E: The package lists or status file could not be parsed or opened.
try :
sudo ufw status verbose
result :
Status: inactive
ish
  • 141,990
klox
  • 403
Based on your test of simply attempting to fetch the google homepage, via wget -q -O- http://www.google.com, there is a firewall FW-1 on the machine/domain jeinfw which seems to be blocking most, if not all outbound http access. (Ping/ICMP is not the same as http, so just because ping works doesn't mean http also does).
That's why apt-get is failing -- instead of the content it expects, whether text, bzip2, gzip or xz, it always gets this HTML response from the firewall when it requests any file:
<TITLE>Error</TITLE>
<BODY>
<H1>Error</H1>
FW-1 at jeinfw: Access denied.
</BODY>
To resolve this:
You need to set up the HTTP proxy servers you were given! (I was told via chat!)
Assuming the server is http://139.xxx.xxx.xxx:8080,
  • Open the /etc/profile file with sudo nano (or your favorite editor). This file stores the system-wide variables initialized upon boot into the console.
  • Add the following lines, modifying appropriately. You must duplicate in both upper-case and lower-case because (unfortunately) some programs only look for one or the other:
    http_proxy=http://139.xxx.xxx.xxx:8080/
    https_proxy=http://139.xxx.xxx.xxx:8080/
    ftp_proxy=http://139.xxx.xxx.xxx:8080/
    no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com"
    HTTP_PROXY=http://139.xxx.xxx.xxx:8080/
    HTTPS_PROXY=http://139.xxx.xxx.xxx:8080/
    FTP_PROXY=http://139.xxx.xxx.xxx:8080/
    NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"
Then, set up the proxies for apt-get and Update Manager
  • These programs will not obey the environment variables. Create a file called 95proxies in /etc/apt/apt.conf.d/, and include the following:
    Acquire::http::proxy "http://139.xxx.xxx.xxx:8080/";
    Acquire::ftp::proxy "ftp://139.xxx.xxx.xxx:8080/";
    Acquire::https::proxy "https://139.xxx.xxx.xxx:8080/";
Finally, reboot the server to apply the changes.
ish
  • 141,990
