The file structure of an installed Linux application can be rather complex. Files of the application (applications, libraries, data, configuration) are not contained under a specific directory, but scattered over the system file structure according to conventions, written out in the Filesystem Hierarchy Standard.
Containerized applications (Snap, flatpak, Appimage) will have all of their executables, libraries, data and configuration under specific directories or in single image files. When a containerized package is run, it is exposed to that file system as if that were the real root file system of your computer.
Each application is started with an executable, used to launch the program. Commonly, the executable is installed in a directory that is listed in the $PATH environment variable. You can see the contents of the PATH environment variable with the command printenv PATH.
- For DEB installed programs (e.g. using
apt), system executables go under /usr/sbin, other executables go under /usr/bin.
- For manually installed (e.g.compiled) programs, the recommendation is to place these under a different directory that is not controlled by your package manager, i.e.,
/usr/local/bin or sbin.
Executable binaries and private libraries of a third-party program are commonly placed under /opt, fully distinct from the core operating system components. Typically, executables from under opt/ are either linked into /usr/local/bin, or a wrapper script is placed there so that these "optional" programs also can be launched conveniently by typing a name at the prompt.
Shared libraries, i.e., libraries commonly used by different applications, are typically stored under /usr/lib, those of compiled programs under /usr/local/lib.
Configuration files commonly go under /etc.
Program data (logs, databases, cache, …) used during execution is under /var.
The whereis command can give you an idea of where files of an application live, e.g.
$ whereis firefox
firefox: /usr/bin/firefox /usr/lib64/firefox /etc/firefox /usr/share/man/man1/firefox.1.gz
To find out which files were installed where by a specific package, you can use
dpkg -L $package
