I have been getting this message when I try and put in sudo apt upgrade. I have tried following other information i've found on this but I haven't been able to make it go away. This is what comes up
  `cleaning build area...
make -j24 KERNELRELEASE=6.11.0-19-generic -C /lib/modules/6.11.0-19-generic/build M=/var/lib/dkms/xone/v0.3-57-g29ec357/build...kkkkkk(bad exit status: 2)
kkERROR (dkms apport): binary package for xone: v0.3-57-g29ec357 not found
Error! Bad return status for module build on kernel: 6.11.0-19-generic (x86_64)
Consult /var/lib/dkms/xone/v0.3-57-g29ec357/build/make.log for more information.
dkms autoinstall on 6.11.0-19-generic/x86_64 succeeded for nvidia
dkms autoinstall on 6.11.0-19-generic/x86_64 failed for xone(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
 * dkms: autoinstall for kernel 6.11.0-19-generic
   ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.11.0-19-generic (--configure):
 installed linux-headers-6.11.0-19-generic package post-installation script subprocess returned error exit status 11
dpkg: dependency problems prevent configuration of linux-headers-generic:
 linux-headers-generic depends on linux-headers-6.11.0-19-generic; however:
  Package linux-headers-6.11.0-19-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. Processing triggers for linux-image-6.11.0-19-generic (6.11.0-19.19) ... /etc/kernel/postinst.d/dkms:
  • dkms: running auto installation service for kernel 6.11.0-19-generic
kkSign command: /usr/bin/kmodsign Signing key: /var/lib/shim-signed/mok/MOK.priv Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module: Cleaning build area... make -j24 KERNELRELEASE=6.11.0-19-generic -C /lib/modules/6.11.0-19-generic/build M=/var/lib/dkms/xone/v0.3-57-g29ec357/build...(bad exit status: 2) ERROR (dkms apport): binary package for xone: v0.3-57-g29ec357 not found Error! Bad return status for module build on kernel: 6.11.0-19-generic (x86_64) Consult /var/lib/dkms/xone/v0.3-57-g29ec357/build/make.log for more information. dkms autoinstall on 6.11.0-19-generic/x86_64 succeeded for nvidia dkms autoinstall on 6.11.0-19-generic/x86_64 failed for xone(10) Error! One or more modules failed to install during autoinstall. Refer to previous errors for more information.
  • dkms: autoinstall for kernel 6.11.0-19-generic ...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11 dpkg: error processing package linux-image-6.11.0-19-generic (--configure): installed linux-image-6.11.0-19-generic package post-installation script subprocess returned error exit status 11 Errors were encountered while processing: linux-headers-6.11.0-19-generic linux-headers-generic linux-image-6.11.0-19-generic Error: Sub-process /usr/bin/dpkg returned an error code (1)`
I've tried to remove the linux headers and reinstall but that didn't work. Any help would be appreciated.
Crash
