I want to update ubuntu by sudo. when i inserted password, it reply as my password is error. However I checkked all word and number has no mistakes. how i can correct it?
Asked
Active
Viewed 36 times
If your password isn't being accepted, try to check your keyboard layout, as it might have changed. Check if Caps Lock is on. Try typing your password in a text editor to see if it appears correctly. If the issue persists, restart your system and try again. If you're still locked out, you may need to reset your password by booting into recovery mode, remounting the filesystem as read/write, and using the passwd command to set a new password.
