i have been using Ubuntu since last year and now i have installed Ubuntu in my old PC (using Ubuntu in my laptop since last year) and when i installed NVIDIA 340.108 drivers in Ubuntu 20.04 (and 22.04 using kelebek333 ppa) the cuda doesn't work.
I'm new in ask ubuntu so if you can please help me.
when i enter nvidia-smi this shows up:
| NVIDIA-SMI 340.108 Driver Version: 340.108 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce 210 Off | 0000:01:00.0 N/A | N/A |
| 0% 66C P0 N/A / N/A | 192MiB / 1023MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
how can i fix the Not Supported letter in Ubuntu?
PC Information:
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
Subsystem: Elitegroup Computer Systems 4 Series Chipset DRAM Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000b000-0000bfff [size=4K]
Memory behind bridge: fd000000-fe9fffff [size=26M]
Prefetchable memory behind bridge: 00000000ce000000-00000000dfffffff [size=288M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 (prog-if 00 [UHCI])
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) USB UHCI Controller
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 4: I/O ports at ac00 [size=32]
Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 21
Region 4: I/O ports at a880 [size=32]
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin D routed to IRQ 19
Region 4: I/O ports at a800 [size=32]
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 (prog-if 20 [EHCI])
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) USB2 EHCI Controller
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 0: Memory at fcfffc00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) HD Audio Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 25
Region 0: Memory at fcff8000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 17
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: fea00000-feafffff [size=1M]
Prefetchable memory behind bridge: 00000000c0000000-00000000c01fffff [size=2M]
BridgeCtl: Parity- SERR+ NoISA+ VGA- VGA16- MAbort- >Reset- FastB2B-
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5 (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: c0200000-c03fffff [size=2M]
Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff [size=2M]
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 4: I/O ports at a480 [size=32]
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 19
Region 4: I/O ports at a400 [size=32]
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 (prog-if 00 [UHCI])
Latency: 0
Region 4: I/O ports at a080 [size=32]
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 (prog-if 20 [EHCI])
Latency: 0
Region 0: Memory at fcfff800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) (prog-if 01 [Subtractive decode])
Latency: 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: feb00000-febfffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:1f.0 ISA bridge: Intel Corporation 82801JIB (ICH10) LPC Interface Controller
Subsystem: Elitegroup Computer Systems 82801JIB (ICH10) LPC Interface Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller #1 (prog-if 8f [PCI native mode controller, supports both channels switched to ISA compatibility mode, supports bus mastering])
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) 4 port SATA IDE Controller
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: I/O ports at a000 [size=8]
Region 1: I/O ports at 9c00 [size=4]
Region 2: I/O ports at 9880 [size=8]
Region 3: I/O ports at 9800 [size=4]
Region 4: I/O ports at 9480 [size=16]
Region 5: I/O ports at 9400 [size=16]
Kernel driver in use: ata_piix
Kernel modules: pata_acpi
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) SMBus Controller
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at fcfff400 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at 0400 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller #2 (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Elitegroup Computer Systems 82801JI (ICH10 Family) 2 port SATA IDE Controller
Latency: 0
Region 0: I/O ports at 9000 [size=8]
Region 1: I/O ports at 8c00 [size=4]
Region 2: I/O ports at 8880 [size=8]
Region 3: I/O ports at 8800 [size=4]
Region 4: I/O ports at 8480 [size=16]
Region 5: I/O ports at 8400 [size=16]
01:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 210] (rev a2) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. GT218 [GeForce 210]
Latency: 0
Interrupt: pin A routed to IRQ 26
Region 0: Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at d0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at ce000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at bc00 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia
01:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. High Definition Audio Controller
Interrupt: pin B routed to IRQ 17
Region 0: Memory at fe97c000 (32-bit, non-prefetchable) [size=16K]
02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0)
Subsystem: Elitegroup Computer Systems AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
Region 0: Memory at feac0000 (64-bit, non-prefetchable) [size=256K]
Region 2: I/O ports at cc00 [size=128]
Kernel driver in use: ATL1E
Kernel modules: atl1e
03:00.0 IDE interface: JMicron Technology Corp. JMB368 IDE controller (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Elitegroup Computer Systems JMB368 IDE controller
Region 0: I/O ports at dc00 [size=8]
Region 1: I/O ports at d880 [size=4]
Region 2: I/O ports at d800 [size=8]
Region 3: I/O ports at d480 [size=4]
Region 4: I/O ports at d400 [size=16]
Kernel driver in use: pata_jmicron
Kernel modules: pata_jmicron, pata_acpi
04:01.0 Ethernet controller: VIA Technologies, Inc. VT6105/VT6106S [Rhine-III] (rev 8b)
Subsystem: D-Link System Inc DFE-520TX Fast Ethernet PCI Adapter
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 64 (750ns min, 2000ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at e800 [size=256]
Region 1: Memory at febffc00 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: via-rhine
Kernel modules: via_rhine
04:02.0 Modem: Motorola SM56 Data Fax Modem (rev 04) (prog-if 00 [Generic])
Subsystem: Motorola SM56 Data Fax Modem
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Latency: 64 (250ns min, 15500ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at febfe000 (32-bit, non-prefetchable) [size=4K]
Region 1: I/O ports at e400 [size=256]
