I've been trying to install TeX-macs via gnome terminal in Ubuntu, but running the command sudo apt-get install texmacs the following errors occur:
Terminal output:
Building dependency tree... Done
The following packages have unmet dependencies: texmacs : Depends: guile-1.8-libs (>= 1.8.5+1-2ubuntu1) but it is not installable Depends: libqt4-svg (>= 4:4.5.3) but it is not installable Depends: libqtcore4 (>= 4:4.7.0~beta1) but it is not installable Depends: libqtgui4 (>= 4:4.8.0) but it is not installable Recommends: libjpeg-progs or libjpeg-mmx-progs but it is not installable Recommends: libtiff-tools Recommends: librsvg2-bin Recommends: xfig but it is not going to be installed Recommends: texlive-bibtex-extra but it is not going to be installed or pybtex but it is not going to be installed or nbibtex but it is not installable E: Unable to correct problems, you have held broken packages.
I've actually followed the official guide to the installation on the ubuntu-help site, and also the guite on the TeXmacs site.
I've tried to run the commands add-apt-repository "deb http://ftp.texmacs.org/TeXmacs/tmftp/repos/apt/ yakkety universe" to add the universal repo but it still does not work.
