  1. How do I install this Rosegarden Freedom ? I downloaded it but all I got was files and I don't know how to handle them.
  2. Where did disappear Linux Multimedia Studio LMMS which I downloaded but it did not appear on the launcher ? Neither cannot I find LMMS with Terminal.
  3. Why there's a red drop on the launcher which says Waiting to install and what should I do ? I downloaded Qsynth and it appears when clicking the red drop but still there appears text Waiting to install.
Thank You
antti
  1. Rosegarden can be installed through the software center - that handles the installation for you.
    Install via the software center
  2. LMMS needs to be started with the command line after installation (again through the software center). Run lmms in a terminal. If it does not start, run sudo apt-get install lmms
  3. try restarting your machine and installing the software again.
If I were you I would run the following in the command line: sudo apt-get install rosegarden lmms qsynth. This will install all 3 packages.
Qsynth:
jackweirdy
  • 3,520
  • 27
  • 42
