I'd like to add empathy to the list of programs to start up when starting an session, i looked at this page: https://help.ubuntu.com/community/AddingProgramToSessionStartup but I don't think this is adapted to 12.04 (see section "How to find the appropriate startup command")
So, how can i find out the command for a program to add to startup programs?
wouter205
  • 1,181
To find out the command for any program you should type this in the terminal-
whereis *application name*
For example,
If you want to find out the command to run Gedit the type in the terminal-
whereis gedit
and you will get an output like this-
gedit: /usr/bin/gedit /usr/lib/gedit /usr/bin/X11/gedit /usr/share/gedit /usr/share/man/man1/gedit.1.gz
out of that,the very first path you see-/usr/bin/gedit is the path to the executable file...Which should be added in the startup applications list.. :)
Hope it helps
Nirmik
  • 7,938
With
ps x -o args
you can get a list of running processes including the arguments that have been passed to the command.
