I have a problem working with the Fn hotkeys on my brand new laptop Asus. I cannot change my volume, screen brightness, keyboard back light and other minor functions. I have tested many possible solutions, but without any sucess. Thank you!
I aprecciate some help!
ish
  • 141,990
Diogo
  • 71
The first thing I would try is to run xev from the terminal and try pressing the keys in question.
See what KeyPress events it reports. That might point to a solution you can find on your own or you could post them here.
otus
  • 873
Well, assuming you're using 12.04 LTS, the hot key setting is more included with the default operating system. I has an ASUS eeePC 900 and when I went from Windows XP to Windows 7, I lost functionality of my function keys as you have. My recommendation, is to simply goto: System Settings > Keyboard > Shortcuts (This is a tab located at the top.) and then create a custom short-cut as the computer has listed on the keyboard for the functions you desire. That would seem to be the easiest way, I don't know about keyboard backlight however, that sounds as if it would be managed with an included tool made specifically for the computer, not included with the operating system in question.
esnowrackley
  • 563
  • 33
There is a solution. You can see my answer to a similar question for the same hardware here if it can help you.
Even simpler, just reinstall the driver from the Asus website or CD. I've had this issue twice now. It's to do with your drivers.
belacqua
  • 23,540
Phil
