I have followed the installation guide step by step and when I enter sudo apt install ros-humble-desktop It give the dependencies error
Reading package lists... Done
Building dependency tree... Done
libpulse-dev : Depends: libpulse0 (= 1:15.99.1+dfsg1-1ubuntu1) but 1:15.99.1+dfsg1-1ubuntu2.2 is to be installed
Depends: libpulse-mainloop-glib0 (= 1:15.99.1+dfsg1-1ubuntu1) but 1:15.99.1+dfsg1-1ubuntu2.2 is to be installed
libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3.7) but 249.11-0ubuntu3.12 is to be installed
libusb-1.0-0-dev : Depends: libusb-1.0-0 (= 2:1.0.25-1ubuntu1) but 2:1.0.25-1ubuntu2 is to be installed
python3-dev : Depends: python3 (= 3.10.6-1~22.04) but 3.10.6-1~22.04.1 is to be installed
i also have to add that I am completely new to linux and my linux version is Ubuntu 22.04.5 LTS
the out put of grep -e '-updates' /etc/apt/sources.list{,.d/*}
is:
/etc/apt/sources.list:# deb-src http://ir.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
/etc/apt/sources.list:# deb-src http://ir.archive.ubuntu.com/ubuntu/ jammy-updates universe
/etc/apt/sources.list:# deb-src http://ir.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
/etc/apt/sources.list.d/ubuntu-esm-apps.list:# deb https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates main
/etc/apt/sources.list.d/ubuntu-esm-apps.list:# deb-src https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates main
/etc/apt/sources.list.d/ubuntu-esm-apps.list.save:# deb https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates main
/etc/apt/sources.list.d/ubuntu-esm-apps.list.save:# deb-src https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates main
/etc/apt/sources.list.d/ubuntu-esm-infra.list:# deb https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates main
/etc/apt/sources.list.d/ubuntu-esm-infra.list:# deb-src https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates main
/etc/apt/sources.list.d/ubuntu-esm-infra.list.save:# deb https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates main
/etc/apt/sources.list.d/ubuntu-esm-infra.list.save:# deb-src https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates main
