I have a fresh copy of Kubuntu 24.04
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.2 LTS
Release: 24.04
Codename: noble
Within this release Thunderbird is installed as snap.
$ snap version
snap 2.67
snapd 2.67
series 16
ubuntu 24.04
kernel 6.8.0-53-generic
$ sudo aa-status |grep thunderbird
[sudo] password for karsten:
snap-update-ns.thunderbird
snap.thunderbird.hook.configure
snap.thunderbird.hook.install
snap.thunderbird.hook.post-refresh
snap.thunderbird.thunderbird
thunderbird//snap.thunderbird.thunderbird
thunderbird
/snap/thunderbird/663/usr/lib/thunderbird/thunderbird-bin (147997) snap.thunderbird.thunderbird
/snap/thunderbird/663/usr/lib/thunderbird/thunderbird-bin (148180) snap.thunderbird.thunderbird
I have installed a NAS service via samba (autofs).
$ more /etc/auto.master.d/auto.karsten
ablage -fstype=cifs,vers=2.1,rw,credentials=/home/karsten/.smbcredentials,file_mode=0777,dir_mode=0777 ://192.168.1.20/ablage
When I try to add an attachement to an email from the local drive, it works. When I try to add an attachement to an email from network drive, I get a message Error opening directory '/home/karsten/HomeServer/ablage/Haus': Permission denied
I can find some entries in the log:
2025-02-21T21:16:42.584883+01:00 LinuxKirschbaum kernel: audit: type=1400 audit(1740169002.582:2166): apparmor="DENIED" operation="open" class="file" profile="snap.thunderbird.thunderbird" name="/etc/fstab" pid=147997 comm="thunderbird-bin" requested_mask="r" denied_mask="r" fsuid=1001 ouid=0
2025-02-21T21:16:42.587855+01:00 LinuxKirschbaum kernel: audit: type=1400 audit(1740169002.585:2167): apparmor="DENIED" operation="open" class="file" profile="snap.thunderbird.thunderbird" name="/run/mount/utab" pid=147997 comm="thunderbird-bin" requested_mask="r" denied_mask="r" fsuid=1001 ouid=0
2025-02-21T21:16:42.644055+01:00 LinuxKirschbaum dbus-daemon[1353]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.1371' (uid=1001 pid=147997 comm="/snap/thunderbird/663/usr/lib/thunderbird/thunderb" label="snap.thunderbird.thunderbird (enforce)")
2025-02-21T21:16:42.646832+01:00 LinuxKirschbaum kernel: audit: type=1400 audit(1740169002.644:2168): apparmor="DENIED" operation="open" class="file" profile="snap.thunderbird.thunderbird" name="/run/mount/utab" pid=147997 comm="thunderbird-bin" requested_mask="r" denied_mask="r" fsuid=1001 ouid=0
2025-02-21T21:16:42.649830+01:00 LinuxKirschbaum kernel: audit: type=1400 audit(1740169002.647:2169): apparmor="DENIED" operation="open" class="file" profile="snap.thunderbird.thunderbird" name="/home/karsten/HomeServer/ablage/Haus/" pid=147997 comm="pool-thunderbir" requested_mask="r" denied_mask="r" fsuid=1001 ouid=0
The changes in the Apparmor profile have no effect, e.g.(/var/lib/snapd/apparmor/profiles/snap.thunderbird.thunderbird):
profile "snap.thunderbird.thunderbird" flags=(attach_disconnected,mediate_deleted) {
#include <abstractions/base>
#include <abstractions/consoles>
#include <abstractions/openssl>
owner /home/karsten/HomeServer/ablage/ rw,
/etc/fstab r,
# While in later versions of the base abstraction, include this explicitly
# for series 16 and cross-distro
/etc/ld.so.preload r,
Which configuration is needed to allow Thunderbird to access the network resource /home/karsten/HomeServer/ablage/Haus/?
Which rule should be added here?
Any suggestion is appreciated. I am completely at a loss.
