 * dkms: running auto installation service for kernel 6.8.0-53-generic
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8152/2.08.0/source/dkms.conf)
Deprecated feature: REMAKE_INITRD (/etc/dkms/framework.conf)
Sign command: /usr/bin/kmodsign
Binary update-secureboot-policy not found, modules won't be signed
Building module:
Cleaning build area...
make -j4 KERNELRELEASE=6.8.0-53-generic -C /lib/modules/6.8.0-53-generic/build M=/var/lib/dkms/r8152/2.08.0/build...(bad exit status: 2)
ERROR (dkms apport): binary package for r8152: 2.08.0 not found
Error! Bad return status for module build on kernel: 6.8.0-53-generic (x86_64)
Consult /var/lib/dkms/r8152/2.08.0/build/make.log for more information.
dkms autoinstall on 6.8.0-53-generic/x86_64 failed for r8152(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
 * dkms: autoinstall for kernel 6.8.0-53-generic
   ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.8.0-53-generic (--configure):
 installed linux-headers-6.8.0-53-generic package post-installation script subprocess returned error exit status 11
Setting up libpython3.12-stdlib:amd64 (3.12.3-1ubuntu0.5) ...
Setting up libwebkitgtk-6.0-4:amd64 (2.46.6-0ubuntu0.24.04.1) ...
Setting up python3.12 (3.12.3-1ubuntu0.5) ...
Setting up gir1.2-javascriptcoregtk-6.0:amd64 (2.46.6-0ubuntu0.24.04.1) ...
dpkg: dependency problems prevent configuration of linux-headers-generic:
 linux-headers-generic depends on linux-headers-6.8.0-53-generic; however:
  Package linux-headers-6.8.0-53-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure):
 dependency problems - leaving unconfigured
Setting up gir1.2-javascriptcoregtk-4.1:amd64 (2.46.6-0ubuntu0.24.04.1) ...
No apport report written because the error message indicates its a followup error from a previous failure.
  Setting up libpython3.12t64:amd64 (3.12.3-1ubuntu0.5) ...
Setting up gir1.2-webkit-6.0:amd64 (2.46.6-0ubuntu0.24.04.1) ...
Setting up gir1.2-webkit2-4.1:amd64 (2.46.6-0ubuntu0.24.04.1) ...
dpkg: dependency problems prevent configuration of linux-generic:
 linux-generic depends on linux-headers-generic (= 6.8.0-53.55+1); however:
  Package linux-headers-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
Setting up libpython3.12-dev:amd64 (3.12.3-1ubuntu0.5) ...
  Setting up python3.12-dev (3.12.3-1ubuntu0.5) ...
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for libc-bin (2.39-0ubuntu8.4) ...
Processing triggers for systemd (255.4-1ubuntu8.5) ...
Processing triggers for man-db (2.12.0-4build2) ...
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for linux-image-6.8.0-53-generic (6.8.0-53.55) ...
/etc/kernel/postinst.d/dkms:
Building module:
   ...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.8.0-53-generic (--configure):
 installed linux-image-6.8.0-53-generic package post-installation script subprocess returned error exit status 11
No apport report written because MaxReports is reached already
 linux-generic
Restarting Ubuntu currently right now causes a kernal panic, so I have to manually select the previous version.
Not entirely sure what the actual problem is from the multiple errors. Anyone have a guess on what knot to start working on to pull the kink out?
