Installing krb5-user on ubuntu 22.04.5 in an air-gapped env (no internet / access to ubuntu repo). Created a ubuntu mirror and enabled internally. install complains for specific version required. Need help to figure out how to work around this issue.
# uname -a
Linux hostname 5.15.0-119-generic #129-Ubuntu SMP Fri Aug 2 19:25:20 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
apt install krb5-user
Reading package lists... Done
Building dependency tree... Done
krb5-user : Depends: libkrb5-3 (= 1.19.2-2) but 1.19.2-2ubuntu0.4 is to be installed
apt show libkrb5-3 -a
Package: libkrb5-3
Version: 1.19.2-2ubuntu0.4
Status: install ok installed
Priority: required
Section: libs
Source: krb5
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Sam Hartman <hartmans@debian.org>
Installed-Size: 1,077 kB
Depends: libc6 (>= 2.34), libcom-err2 (>= 1.43.9), libk5crypto3 (>= 1.15~beta1), libkeyutils1 (>= 1.5.9), libkrb5support0 (= 1.19.2-2ubuntu0.4), libssl3 (>= 3.0.0~~alpha1)
Recommends: krb5-locales
Suggests: krb5-doc, krb5-user
Breaks: libapache2-mod-auth-kerb (<= 5.4-2.4), libsmbclient (<= 2:3.6.1-2), sssd (<= 1.2.1-4.3)
Homepage: http://web.mit.edu/kerberos/
Download-Size: unknown
APT-Manual-Installed: no
APT-Sources: /var/lib/dpkg/status
Description: MIT Kerberos runtime libraries
Kerberos is a system for authenticating users and services on a network.
Kerberos is a trusted third-party service. That means that there is a
third party (the Kerberos server) that is trusted by all the entities on
the network (users and services, usually called "principals").
This is the MIT reference implementation of Kerberos V5.
This package contains the runtime library for the main Kerberos v5 API
used by applications and Kerberos clients.
Package: libkrb5-3
Version: 1.19.2-2
Priority: required
Section: libs
Source: krb5
Origin: Ubuntu
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Depends: libc6 (>= 2.34), libcom-err2 (>= 1.43.9), libk5crypto3 (>= 1.15~beta1), libkeyutils1 (>= 1.5.9), libkrb5support0 (= 1.19.2-2), libssl3 (>= 3.0.0~~alpha1)
Task: minimal, server-minimal
Download-Size: 356 kB
APT-Sources: http://MIRROR-ubuntu-repo-server/ubuntu-repo/archive.ubuntu.com/ubuntu jammy/main amd64 Packages
