I have an Rpi 5, with Ubuntu 24.04.2 LTS and the following installed.
$ dpkg --list | grep xtable
ii  libxtables12:arm64              1.8.10-3ubuntu2                         arm64        netfilter xtables library
ii  xtables-addons-common           3.25-2build1                            arm64        Additional targets and matches for iptables [tools, libs]
ii  xtables-addons-dkms
These are the same packages as I have installed on a x64amd machine with the same OS.
After I download and build the geoip data (with xt_geoip_build) and try to add the required firewall rules with the module, iptables says it can't find it.
And I see this:
$ modprobe xt_geoip
modprobe: FATAL: Module xt_geoip not found in directory /lib/modules/6.8.0-1018-raspi
Does anyone know how I can get the packages for this to work as I have on the x64amd? I'd rather not compile from source if possible.
TommyPeanuts
  • 1,147
This seems to have been due to the kernel headers package not being installed. So I ran:
sudo apt-get install linux-headers-$(uname -r)
After which I saw various modules being built. I then tried:
sudo depmod -a
followed by:
lsmod | grep xtables which showed the module had loaded.
I could then add the firewall rules.
TommyPeanuts
  • 1,147
