Good day.
Running apt upgrade I get the following:
Fetched 972 kB in 1s (799 kB/s)
Reading package lists... Done
Building dependency tree... Done
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@Slim-7i:/home/dchapman# apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
libpython3.13-stdlib python3.13
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/5182 kB of archives.
After this operation, 12.0 MB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 51921 files and directories currently installed.)
Preparing to unpack .../python3.13_3.13.2-1+noble1_amd64.deb ...
Unpacking python3.13 (3.13.2-1+noble1) over (3.13.0-1+noble1) ...
dpkg: error processing archive /var/cache/apt/archives/python3.13_3.13.2-1+noble1_amd64.deb (--unpack):
trying to overwrite '/usr/bin/python3.13', which is also in package python3.13-minimal 3.13.0-1+noble1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../libpython3.13-stdlib_3.13.2-1+noble1_amd64.deb ...
Unpacking libpython3.13-stdlib:amd64 (3.13.2-1+noble1) over (3.13.0-1+noble1) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.13-stdlib_3.13.2-1+noble1_amd64.deb (--unpack):
trying to overwrite '/etc/python3.13/sitecustomize.py', which is also in package libpython3.13-minimal:amd64 3.13.0-1+noble1
Do I have a package collision? What can I do to solve this?
Thanks,
