I accidentally removed gnome by downgrading a package. I forgot which package I downgraded and which caused this problem. When I try to fix this problem by running
sudo apt install ubuntu-gnome-desktop I get the following error message:
Reading package lists...
Building dependency tree...
Reading state information...
gstreamer1.0-pipewire : Depends: pipewire (= 0.3.48-1ubuntu1) but it is not installable
Depends: libpipewire-0.3-0 (= 0.3.48-1ubuntu1) but 0.3.48-1ubuntu3 is to be installed
nautilus : Depends: libnautilus-extension1a (= 1:42.2-0ubuntu2.1) but 1:42.6-0ubuntu1 is to be installed
Recommends: gvfs-backends
ubuntu-desktop : Depends: gnome-control-center but it is not installable
Recommends: gnome-remote-desktop but it is not installable
Recommends: gvfs-fuse but it is not installable
Recommends: pulseaudio-module-bluetooth but it is not installable
ubuntu-desktop-minimal : Depends: gnome-control-center but it is not installable
I have tried countless things to resolve this issue and reinstall ubuntu-gnome-desktop but have found no solutions.
