I am looking for an application to display in real-time the memory usage of my NVIDIA graphics card. Ideally I would like to have something similar to the little applet graph you can get through the System Monitor applet in GNOME.
Anybody knows if such application exists?
Dan
  • 673
I haven't seen an applet but you can run the following in the terminal window:
nvidia-smi
Perhaps this will help you search for the exact thing you're looking for.
I did find this http://www.matrix44.net/blog/?p=876 but not sure what desktop you are using
If you are using gnome 3 then you might want to hack this https://extensions.gnome.org/extension/82/cpu-temperature-indicator/ to use nvidia-smi information instead (see comments at the bottom of that page - people discussing nvidia-smi)
Moog
  • 353
nvidia-settings show the used memory as well
mike
If nvidia-smi and/or nvidia-settings are terminal commands which give the information you need, perhaps take the next step and write a script which calls those commands and gives you the output you want as text.
Then install indicator-sysmonitor from here and add your script to indicator-sysmonitor as one of the sensors (and ditch the other sensors).
Bernmeister
  • 1,149
