An older WD external USB drive suddenly fails to provide data access today.
lsusb | grep Western returns
Bus 001 Device 006: ID 1058:0730 Western Digital Technologies, Inc. My Passport Essential (WDBACY)
lsblk -o model,name,fstype,size,label,mountpoint returns:
MODEL              NAME   FSTYPE     SIZE LABEL MOUNTPOINT
                   loop0  squashfs     4K       /snap/bare/5
                   loop1  squashfs  63.4M       /snap/core20/1974
                   loop2  squashfs  63.7M       /snap/core20/2434
                   loop3  squashfs  73.9M       /snap/core22/1722
                   loop4  squashfs  73.9M       /snap/core22/1748
                   loop5  squashfs 274.8M       /snap/firefox/5561
                   loop6  squashfs   258M       /snap/firefox/5701
                   loop7  squashfs 349.7M       /snap/gnome-3-38-2004/143
                   loop8  squashfs 505.1M       /snap/gnome-42-2204/176
                   loop9  squashfs   516M       /snap/gnome-42-2204/202
                   loop10 squashfs  91.7M       /snap/gtk-common-themes/1535
                   loop11 squashfs  12.2M       /snap/snap-store/1216
                   loop12 squashfs  12.3M       /snap/snap-store/959
                   loop13 squashfs  53.3M       /snap/snapd/19457
                   loop14 squashfs  44.4M       /snap/snapd/23545
                   loop15 squashfs   452K       /snap/snapd-desktop-integration/83
                   loop16 squashfs   568K       /snap/snapd-desktop-integration/253
                   loop17 squashfs  64.4M       /snap/sublime-text/187
                   loop18 squashfs  64.4M       /snap/sublime-text/196
PNY CS900 2TB SSD  sda               1.8T
                   ├─sda1              1M
                   ├─sda2 vfat       513M       /boot/efi
                   └─sda3 ext4       1.8T       /
My Passport 0730   sdb             931.5G
hp DVD RW AD-7701H sr0              1024M
sudo smartctl -a /dev/sdb returns:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.8.0-52-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION === Model Family: Western Digital Elements / My Passport (USB, AF) Device Model: WDC WD10TMVW-11ZSMS1 Serial Number: WD-WXR1AB037274 LU WWN Device Id: 5 0014ee 1ae3abe13 Firmware Version: 01.01A01 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Sat Feb 8 22:01:04 2025 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled
=== START OF READ SMART DATA SECTION === SMART Status command failed: scsi error unsupported field in scsi command SMART overall-health self-assessment test result: PASSED Warning: This result is based on an Attribute check.
General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (22200) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 255) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x7035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported.
SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 197 192 051 Pre-fail Always - 63 3 Spin_Up_Time 0x0027 216 150 021 Pre-fail Always - 2200 4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3166 5 Reallocated_Sector_Ct 0x0033 192 192 140 Pre-fail Always - 166 7 Seek_Error_Rate 0x002e 182 181 000 Old_age Always - 175 9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2023 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 524 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 143 193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 9153 194 Temperature_Celsius 0x0022 110 103 000 Old_age Always - 40 196 Reallocated_Event_Count 0x0032 195 158 000 Old_age Always - 5 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1 No Errors Logged
SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
NOTABLE: smartctl diagnostic returned:
gatorback
  • 6,523
