I recently switched from Windows 11 to Ubuntu 24.04.1, and I’m experiencing an issue with my Bluetooth devices. I have three devices connected to my desktop PC: a Dell Wireless Keyboard, a Dell Wireless Mouse, and a Dell Wireless Headset. All devices are paired and show up correctly in the Bluetooth settings (taskbar > Bluetooth).
Here’s the problem: after restarting my PC, the keyboard and mouse auto-connect just fine, but the headset does not. While the headset appears in the Bluetooth device list, the "Connect" button is visible, and when I click it, nothing happens. The only way to reconnect the headset is to manually put it in pairing mode and then click "Connect."
Note: The same issue occurs if I manually disconnect the headset from "Bluetooth Settings." Once disconnected, I am unable to reconnect it unless I put the headset back into pairing mode.
When I was using Windows 11, the headset would automatically reconnect after restarting the PC, as expected. Is there any way to force Ubuntu to reconnect the headset automatically after a restart so I don’t have to repeatedly put it in pairing mode?
System Specs:
OS: Ubuntu 24.04.1
PC: Dell Precision 3680 Tower
Bluetooth Adapter: Intel Wi-Fi 6/6E (6GHz) AX211 2x2 Bluetooth 5.3 Wireless Card (External Antenna)
Headset: Dell Headset WL5022
Any help would be greatly appreciated.
Thank you in advance!
