HP Compaq dc5750 small form factor Athlon 64 X2 3800+ 2.0GHz 2GB 160GB
On starting the system it displayed this message:
If you are running Unix, you need to configure your system using the computer setup utility (F10)
Attempts to install 12.04 64 bit from a USB flash stick cause this message:
usi-partman crashed
usi-partman failed with error code 10...
I assume there is a connection between the two. Which settings need to be changed?
The installer error you encountered indicate a failure to access you hard disk(s) for partitioning. This may be due to wrong or not working settings in the BIOS storage access.
In the HP BIOS configuration tool - running with F10 on boot - you may find this in the Storage -> Storage Options -> SATA Emulation menu. Remember the settings there and try with IDE.
Takkat
  • 144,580
